Strong interference
1070 8 2017-5-8
Leonard2017
Flight distance : 29098 ft
Had a first real flight of my new standard 3 last week. Was flying in a wide open field with absolutely no electrical or magnetic interference. While flying had continuous strong interference detected, be careful when flying long distances. This copter is brand new, why am I getting this warning when I am away from anything that would interfere with it? I am sure it warned me twenty times or more. I am now afraid to fly this new machine, fearing that it will fly away on its own or fall out of the sky. Any suggestions or is this just the way it's going to behave?
2017-5-8
Michgolden
Flight distance : 822851 ft
I used to get those literally all the time but I haven't since i updated the app to the latest IOS version.(I do believe it's 3.1.10). On the old version they popped up almost non stop. I also fly in the country so I pretty much ignored them and never had an issue although they were VERY annoying. I am on an older firmware (1.7.9) but like I said they were on there all the time until the app itself was updated. Now I only see them if i fly by a house, I'm assuming they have wifi or something. I don't think I would worry about it.
2017-5-8
fans727218f7
Flight distance : 11004 ft
Michgolden Posted at 2017-5-8 08:12
I have the lasted iOS update and started getting the warning in places I hadn't before.  But my problem started a short time ago and long after the update.  I have also been having the satelite signal drop suddenly during flight causing as loss of control of the p3s, often at 2200 feet.
2017-5-8
DJI-Jamie
Flight distance : 112405 ft
Could you please clarify what mobile device you're using and which Go app version you're running?
2017-5-8
fans727218f7
I'm using a iPad mini 3 with Go App v 3.1.10
2017-5-8
Bradders
Flight distance : 862283 ft
My Phantom 3 std always says there is interference where ever I fly it, even in the most open areas. I think its the older technology of the phantom 3's
2017-5-9
Leonard2017
Thanks for the reply guys. I have the latest version, 3.1.10
I wonder if I deleted and downloaded the app again would it help?
If I did this would I lose my flight logs and other info?
2017-5-9
Michgolden
If you sync your records first you'll be good. Just re-sync after you reinstall the app and log in.
2017-5-9
fanscb15c80e
Flight distance : 34275 ft
So I just got p3s and all together 7 flights so far every flight it's showing same message "Strong interference detected fly carefully long distances" all 7 sights different one is so remote that I didn't expected to see that warning still same issue, I looked at at least three posts but no solution is found on any forum and don't see any responses from Dji, Did anybody successfully resolved the issue yet?
2017-7-5
