Please help!! unable toupgrade/downgrade firmware
2787 25 2015-3-8
craigr9
The last upgrade that I installed was 3.08.
I tried to upgrade to 3.12, today, and it shows that I am at 3.10, with no updates available.
I refreshed, clicked the no updates, refreshed, uninstalled, and reinstalled assistant 3.8 (PC)
I am unable to upgrade, or downgrade.
II am unable to attach a screenshot, don't know why.
Please help
Thanks
2015-3-8
Capt. Bill
Make sure you have version 3.8 of the Phantom assistant. Version 3.6 will only download firmware V3.12
2015-3-8
craigr9
Capt. Bill Posted at 2015-3-9 02:29
Make sure you have version 3.8 of the Phantom assistant. Version 3.6 will only download firmware V3. ...
I have 3.8 installed
2015-3-8
Naza-PA
I think, Phantom assistant. Version 3.6 will only download firmware V3.08 (another words - it allows downgrade)
2015-3-8
Northofthe49th
Doing a hard reset on the Phantom and starting over will yield the best result!Google: DJI Phantom hard reset
2015-3-8
crash1sttime
Flight distance : 1047503 ft
i thought 3.6 asst allows you to flash 3.08 firmware and 3.8 asst will flash to 3.12 firmware (dam DJI for having the same bloody numbers for firmware and assistant software)
2015-3-8
craigr9
Northofthe49th Posted at 2015-3-9 02:44
Doing a hard reset on the Phantom and starting over will yield the best result!Google: DJI Phantom h ...
I am not too sure about doing the hard reset. The one video says that there is a possibility of hosing the controller board.
I there any other way, other than shorting the pins on the controller
2015-3-8
craigr9
I followed the video, for the hard reset.
The software shows firmware 0, and no updates available.
I tried using software 3.6 and 3.8. Neither work.
When I power the phantom, without the reset cable, it shows firmware 3.1
No idea what to try next
2015-3-8
Northofthe49th
No clue what you mean by power the Phantom without the reset cable it shows firmware 3.1..where and on what device ?..leave your phone off and out of it for now if that is the inference....
Read all below........... then go!
After you have done the hard reset..turn off your Phantom...
Make sure you have dumped and reloaded your Phantom Assistant software (v3.8 which includes the 3.12 firmware) as well, if not, please re do it! NOW!
Now, plug into the Phantom then power the Phantom up, then launch the Phantom Assistant then do your install/updates....it works
2015-3-8
timf419
Northofthe49th Posted at 2015-3-9 05:21
No clue what you mean by power the Phantom without the reset cable it shows firmware 3.1..where and  ...
Having similar issue with the firmware.  I followed your list, even switching to a different computer.  Now the assistant will not log into my account.  Keep getting a servicer busy error.  Very odd...  Similar behavior between Mac and Windows OS.
2015-3-8
craigr9
I followed the video, on youtube, for a hard reset.
With the jumper cable installed, it shows firmware 0, but does not show any updates available.
I clicked the check for updates, many times.
I uninstalled and installed the assistant several times.
Went back to 3.6, still no updates.
3.8 - no updates available.
After removing the jumper cable, and restarting the phantom, it shows 3.1,
It does not appear that the hard reset has wiped the firmware.
I have tried this using Windows 8.1 and a MacBook
I am at a total loss.
2015-3-9
gsp171
If your phantom operates correctly, why would you try to update the software?
2015-3-9
Gerry1124
What version of the Phantom do you have?
2015-3-9
adrianjacobs
gsp171@mchsi.co Posted at 2015-3-10 00:16
If the phantom operates correctly, why would Dji try to upgrade it?
2015-3-9
Gerry1124
adrianjacobs@nt Posted at 2015-3-10 00:31
Major New Features:
a)    No-Fly Zones have been updated to include a 25km radius centered in Washington, DC.
b)    The compass calibration program has been optimized to improve reliability.
c)    When automatic landing is initiated, users can now continue to control the aircraft's position and altitude. During this process, the maximum speed of ascent is 1 m/s.
d)    After an automatic landing has been completed and the motors have stopped spinning, users can immediately restart the motors and begin a new flight.
Updates
a)    Flight controller firmware has been updated to v3.12.
2015-3-9
gsp171
Those changes are not necessary and to me, they are stupid changes coupled with all the hassle to make it fly again after update
2015-3-9
Gerry1124
gsp171@mchsi.co Posted at 2015-3-10 00:41
Those changes are not necessary and to me, they are stupid changes coupled with all the hassle to ma ...
Then don't do the upgrade, some people rather like the changes.  it's all your choice.  I did the upgrade and can now get some sats inside my house where before I always got 0.  I have no problem with these upgrades,  it flies perfectly.
2015-3-9
gsp171
You got  that right, it is ridiculous to force these updates!!!
I will NEVER plug my Phantom into the internet again, EVER...
2015-3-9
Gerry1124
gsp171@mchsi.co Posted at 2015-3-10 00:44
I will NEVER plug my Phantom into  ...
That is your choice.
2015-3-9
gsp171
Gerry1124 Posted at 2015-3-10 00:43
Then don't do the upgrade, some people rather like the changes.  it's all your choice.  I did the  ...
IT IS NOT your choice!!!! plug it into the net and they push it!!!!
2015-3-9
Gerry1124
gsp171@mchsi.co Posted at 2015-3-10 00:48
I had the choice, it didn't automatically download, I had to select download update to get it.
2015-3-9
adrianjacobs
Hmmm, I was being ironic.
Progress, eh? ;-)
2015-3-9
gsp171
Gerry1124 Posted at 2015-3-10 00:50
Well there is inconsistency here, my Phantom firmware primary update months ago were not prompted, only the sub element firmware is prompted
Many have comment on the automatic Push of this software.
2015-3-9
Gerry1124
gsp171@mchsi.co Posted at 2015-3-10 00:54
Well there is inconsistency here, my Phantom firmware primary update months ago were not prompted, ...
One of mine I did upgrade and one of them I did not upgrade, but I can connect either one to the computer and it says there is an upgrade to the one I did not do and do you want to upgrade now,  I click cancel and it won't do the upgrade.
2015-3-9
jayeffu2
If you are running p2 Assistant v3.8 - how can you see if you have installed the MC firmware v3.12?
IGNORE - the upgrade is now displaying
2015-3-9
kirk2579
Flight distance : 37415 ft
not true! false info!
You have to CHOSE update.
It is not automatic and CAN be reflashed to 3.08 if needed.
2015-3-12
