Nelsonlee
Flight distance : 2779203 ft
Malaysia
Use DJI Assistant 2 software PC/Mac install to your PC/MAC, run the application and connect the micro USB to your RC and connect to PC/MAC when the DJI Assistant 2 software detected your RC devices click into it and do (RESET DEFAULT)......and wait the RC resetting.
If your P4 Pro+ RC firmware is 1.1.30 and Go 4 app version is 4.0.4 then go DJI Phantom 4 Advanced page to download this Phantom 4 Advanced+ Remote Controller Firmware, Then extract to root fo sdcard and insert to your P4 Pro+, then on your RC go to system not GO 4 app and select update, on top right corner press the three dot and select manual update from sdcard and wait for the system update.
After finished it will automatic restart the RC, then you can check the latest RC device firmware will be v1.1.50 and the GO 4 app will be v4.0.6.
I have done for this and so far working well. |
