Cetacean
Flight distance : 2528264 ft
Genghis9 Posted at 2018-3-21 11:15
OK
I just thought the issue was about the color, for which I assumed there were differences based on the color...
My bro and I swap batts or I should say he has used some of mine in his P4S, mine being the P4P standard batt (aka "high capacity") and he has experienced no issues up or down nor I using them after he did, I didn't expect any either.
Aloha Genghis,
My apologies, it is the difference between the High Capacity battery and the Normal battery that I was talking about. High Capacity and Normal batteries have different firmware (or used to). Unless the Intelligent Battery firmware has been made common to both, you may get a "Firmware Update Required" warning if you swap them.
Since I stopped swapping my apples and oranges, I do not know if that firmware has been made common to both types of batteries. Maybe someone who does still swap the High Capacity and Normal batteries can weigh in on this subject.
Aloha and Drone On! |
