Haha,black battery
2574 30 2018-2-24
zhangqing
Flight distance : 5959009 ft
China
It can be used normally, without a problem.!
P4P
P4P
2018-2-24
ALABAMA
Flight distance : 10442687 ft
Nice contrast too!
2018-2-24
Jeff Millard
Flight distance : 503635 ft
In this post Cetacean has done a nice mix and match in a similar way.
Jeff
2018-2-24
R&L Aerial photography
Flight distance : 298100 ft
I painted my p4 advance fluorescent orange, the controller painted fluorescent lime green and my iPad Pro fluorescent pink. I also wear white gloves when I fly....
2018-2-24
Rodger8
Flight distance : 20145135 ft
It will work fine. I have a spare white one that I use with my Obsidian.
2018-2-24
Todd in Chicago
Flight distance : 513757 ft
Ahhh....The newest addition to the DJI lineup!  The Zebra!  ;-)
2018-2-24
Todd in Chicago
Ahhh....The newest addition to the DJI lineup observed in the wild!  The Zebra!  ;-)  Todd in Chicago
2018-2-24
Montfrooij
Flight distance : 2560453 ft
Black and white, dancing together.
2018-2-24
Matthew Dobrski
Flight distance : 1831050 ft
Hey, KKK to the rescue !!! ...
2018-2-24
zhangqing
Hahaha.......
2018-3-3
zhangqing
Jeff Millard Posted at 2018-2-24 08:31
Jeff
Great,,,,hahaha.
2018-3-3
A CW
Flight distance : 14237874 ft
Nice
2018-3-3
GoldenSun
Flight distance : 681903 ft
Poland
LOL but... why?
2018-3-3
zhangqing
You can try it.
2018-3-19
GoldenSun
Poland
Yeah... right?
2018-3-19
DEUCEDOG
Flight distance : 2501575 ft
cool
2018-3-19
Eric13
Flight distance : 14950167 ft
You may want to remove the sticker from the IR sensor
2018-3-19
hurley171
Flight distance : 549295 ft
I like that look.
2018-3-20
Genghis9
Flight distance : 961 ft
Looks good
Was there any question about a P4P battery working in a P4 black or white?
2018-3-20
RedHotPoker
Flight distance : 165105 ft
Nice contrast, no clash...
RedHotPoker
2018-3-20
Cetacean
Flight distance : 2528264 ft
Genghis9 Posted at 2018-3-20 18:56
Looks good
Aloha Genghis,
     The batteries are interchangeable but the firmware have to be updated.  You are reminded each time a long duration P4P battery is used in a P4 and vise versa.  Unless they fixed that with recent updates.  It was that way back when the P4P first came out.
     I never did find out what the firmware difference was, just that it was needed.  I stopped swapping them.
Aloha and Drone On!
2018-3-21
Genghis9
Cetacean Posted at 2018-3-21 01:33
Aloha Genghis,
OK
I just thought the issue was about the color, for which I assumed there were differences based on the color...
My bro and I swap batts or I should say he has used some of mine in his P4S, mine being the P4P standard batt (aka "high capacity") and he has experienced no issues up or down nor I using them after he did, I didn't expect any either.
Cheers
2018-3-21
Cetacean
Genghis9 Posted at 2018-3-21 11:15
OK
Aloha Genghis,
     My apologies, it is the difference between the High Capacity battery and the Normal battery that I was talking about.  High Capacity and Normal batteries have different firmware (or used to).  Unless the Intelligent Battery firmware has been made common to both, you may get a "Firmware Update Required" warning if you swap them.
     Since I stopped swapping my apples and oranges, I do not know if that firmware has been made common to both types of batteries.   Maybe someone who does still swap the High Capacity and Normal batteries can weigh in on this subject.
Aloha and Drone On!
2018-3-21
Malolojoe
Flight distance : 312844 ft
Two of my three batteries are white that I use in my Obsidian. Obsidian batteries weren't available when I bought them. Work exactly the same for me.
2018-3-21
Genghis9
Cetacean Posted at 2018-3-21 14:02
Aloha Genghis,
It's cool
So let me clarify, yes, as of this past January my brother was using my P4P Batteries in his P4S i.e. using my high capacity batts in his standard model without problem or issue.  No update was required when doing so that either one of us noted.  Now I did not use his lower capacity batt in my P4P but I suspect there would have not been an issue either if I had done so.
Aloha and Fly Safe
2018-3-21
Cetacean
Malolojoe Posted at 2018-3-21 14:23
Aloha Joe,
     Mahalo for the input.  I think the problem may have been solved.  But High Capacity batteries are interchangeable and Normal batteries are interchangeable.  From what Genghis is saying, it looks like High Capacity and Normal batteries are now interchangeable.
     Since I have both and my systems are up-to-date, I will be testing this interchangeability when the weather gives me a break.  Mahalo again!
Aloha and Drone On!
2018-3-22
Cetacean
Genghis9 Posted at 2018-3-21 14:44
It's cool
Aloha and Fly Safe
Aloha Genghis,
     Let me know when you do check it out and I will let you know.  This weather is such a pain right now.
Aloha and Drone On!
2018-3-22
Alex_Law_P4
It doesn't look bad at all. LOL
2018-3-22
Top_Speed1
Flight distance : 377664 ft
[Obsidean owner here]
I was thinking about going the opposite way, since white batteries are le$$ than the black one's.
2018-3-22
Nebuchadnezzar
Flight distance : 3462946 ft
White Spray is cheaper than other ones lol
2018-3-22
Alex_Law_P4
Does it have more flight time? Or is it the same?
2018-3-23
