Gimbal Sunchronous Follow
2766 35 2018-11-17
fans58c5004e
Flight distance : 33048 ft
I have just bought my first drone, a Mavic 2 Pro.
I’m struggling to get smooth yaw movements. I’ve tweaked all the controller settings, but it’s still difficult to achieve.
Doing some research I came across a setting called Gimbal Sunchronius Follow, so I went into the DJI GO 4 app to activate it, only to find it wasn’t there.
Why not? Seems to be exactly what’s needed.
2018-11-17
fans58c5004e
Synchronous
2018-11-17
Hi, we appreciate bringing this query to us. I understand you are currently struggling to get smooth yaw movements. In the app, you will see 3 horizontal dots to the right part of the screen, tap that and locate the first icon (aircraft icon) scroll down to locate the advanced settings, tap EXP, in the EXP settings they set the linear relationship between how much you have to move your stick to how much output you get in response. In all three cases, you want less output for more input which simply increases the level of control you'll have on the sticks. Throttle up and down simply controls how fast the altitude is going to change. This will probably the least important amongst the three. Greatest input in the smoothest that you are looking for is the Rotate left or right part, otherwise known as YAW this will adjust the rotation starts as you start to move your sticks. You may play between 20 increment of 15, this will slow the start of any rotation. I hope that I was able to help you with your current concern today. Fly safely.
2018-11-17
fans58c5004e
DJI Gamora Posted at 11-17 04:46
Thanks, but like I said in my original post, I’ve already done all that. It’s helped, but it’s still not ideal.
Why is there no option for Gimbal Synchronous Follow anymore? Or just do it electronically with the yaw, like I can set a smoothness value for the gimbal tilt.
Cinematic and Tripod mode both smooth out the pitch, roll and braking nicely, but the yaw always starts and stops abruptly, even with the control sensitivity turned all the way down. There needs to be an option to gradually ease into the acceleration/deceleration, even with less-than-delicate control inputs. After all, it’s sudden/fast yaw movements that cause the most jarring motion blur in the footage.
Please give us something to help solve this problem.
2018-11-17
JJBspark
Flight distance : 12686732 ft
does this help you ?  https://forum.dji.com/thread-144117-1-1.html
cheers
JJB
2018-11-17
fans58c5004e Posted at 11-17 05:42
Hi, kindly give us a sample video of the issues you are having for us to check. The  Gimbal Synchronous Follow is not available in Mavic 2 Pro.  However, have you tried adjusting the yaw sensitivity as shown in the photo below? Thank you.
2018-11-17
fans58c5004e
JJBspark Posted at 11-17 05:49
Thanks, but like I’ve said, I’ve already done all that.
I’m just curious as to why they would remove a perfectly useful setting?! What’s the rationale?
2018-11-17
fans58c5004e
DJI Gamora Posted at 11-17 06:04
Yes, I have adjusted that setting also.
I am well aware that the Gimbal Synchronous Follow setting is not available for the Mavic 2 Pro, my question is why?! It seemed that people used it and liked it a lot.
Will you be adding the option back in a future firmware update? I’ve read a lot of people in many forums saying that they too miss this feature.
Makes no sense to me why you’d remove it.
I see little value in sending you any sample footage. Just imagine the yaw starting/stopping abruptly, rather than easing smoothly into and out of the movement. Like I’ve said, adjusting the controller settings has noticeably helped, but it’s still not perfect.
2018-11-17
fans58c5004e
My actual question isn’t being answered.
TL;DR
1) Why did you remove the Gimbal Synchronous Follow setting?
2) Will you be adding it back in a future firmware update?
2018-11-17
fans58c5004e Posted at 11-17 06:20
TL;DR
Hi, I will be forwarding this to our engineers for them to be notified and see what they can do about this. Your patience is highly appreciated.
2018-11-17
Asainz320
Flight distance : 1061594 ft
I dont know where you found that people liked that setting. I made a few posts before where I asked people to show me the difference that setting made, no one was able to show me a difference. I made a couple of videos showing that this Synchronous Follow didnt make a difference if it was on or off. Many have claimed that it made the pan smoother but reasons why or how this makes it smoother do not make sence. If you find a video showing the difference between the setting being on or off makes, please let me know, I would love to see it.
2018-11-17
Aardvark
Flight distance : 384432 ft
TL;DR
Enable Synchronized Gimbal Pan Follow setting is in 'Gimbal Settings' / 'Advanced Settings'.
Does that answer your question ?
2018-11-17
fans58c5004e
Aardvark Posted at 11-17 09:02
It’s not there for the Mavic 2.
2018-11-17
fans58c5004e
Asainz320 Posted at 11-17 08:26
It just makes the gimbal yaw lag behind slightly to smooth out the abrupt start/finish of the turn. Makes sense. That or be able to make the craft turn the same way electronically, so even the most ham-fisted operator can get silky footage.
https://youtu.be/hh5XNk6_A24
2018-11-17
It’s been available on MavicPro for 18 months .
2018-11-17
Asainz320
fans58c5004e Posted at 11-17 10:28
Yes!! That would make sence, but the way it works its the opposite. It advances the gimbal yaw slightly.
2018-11-17
Asainz320
Also that video you shared shows the proper way it should work, but thats not how it works on the Mavic. I have done extensive research on this and I gave up cus no one cared that it doesnt work properly on the Mavic Pro lol.
2018-11-17
fans58c5004e
Asainz320 Posted at 11-17 11:20
I have seen videos where that’s the case, but wasn’t that a bug? I’m sure it’s supposed to work the way I described.
2018-11-17
Asainz320
hallmark007 Posted at 11-17 11:01
Correct, what are you trying to say?
2018-11-17
fans58c5004e
Asainz320 Posted at 11-17 11:24
Also that video you shared shows the proper way it should work, but thats not how it works on the Mavic. I have done extensive research on this and I gave up cus no one cared that it does work properly on the Mavic Pro lol.
Well they need to fix it or offer an alternative. What’s the use of offering modes which smooth out all of the other movements... except yaw?
2018-11-17
fans58c5004e
That may well be the case, but your comment is irrelevant to this discussion.
2018-11-17
Asainz320
fans58c5004e Posted at 11-17 11:24
Look around, you wont find a video of the Mavic doing what that Phantom does in the video you shared. It only does it when you hold the Mavic by hand and turn it. If you turn it while in mid flight you will see it doesnt work.
2018-11-17
Asainz320
This is one of the videos I made showing this issue, but never got a satisfying answer.
https://youtu.be/W7_z1rN6vcg
2018-11-17
A CW
Flight distance : 14588274 ft
Perhaps the removal of the gimbal pan follow on the M2's may have something to do with the ability to yaw the gimbal on the M2's  unlike the previous models which had gimbal pan follow but did not have gimbal yaw.
2018-11-17
fans58c5004e Posted at 11-17 11:28
I don’t know why you need , you can’t even spell it.
2018-11-17
Asainz320 Posted at 11-17 11:25
Sorry read your post wrong, but I agree something that was there but never used, I’ve seen more posts with users thinking there was something wrong with their gimbal, because they had set it and didn’t know what they set.
2018-11-17
Well what is relevant is you can do the same with cinematic mode.
2018-11-17
fans58c5004e
hallmark007 Posted at 11-17 11:55
I get that. There’s clearly a bug then.
My fundamental premise is why isn’t there either a working version of Gimbal Synchronous Follow, or some other alternative way to smooth out abrupt yaw movements? We can soften everything satisfactorily expect yaw. Why?!
2018-11-17
fans58c5004e
‘‘Twas a typo.
2018-11-17
fans58c5004e
‘Twas a typo.
No ability to edit on here.
2018-11-17
fans58c5004e
hallmark007 Posted at 11-17 12:02
Doesn’t smooth the yaw. That’s my point.
2018-11-17
Alex B.
Flight distance : 24101106 ft
Same here, I don’t notice any difference lol
Flysafely all
Alex
2018-11-17
fans58c5004e Posted at 11-17 12:17
It’s very simple to smooth the Yaw, there are plenty of videos on here with very smooth Yaw movements. And cinematic moves will continue in raw with delayed breaking.
2018-11-17
fans58c5004e
hallmark007 Posted at 11-17 13:15
I know. I’ve seen the videos and done all the settings, and used all the different modes, but yaw could still be more gentle.
It’s not just me. Plenty of other people saying the same thing.
2018-11-17
fans58c5004e
DJI Gamora Posted at 11-17 06:23
Clearly a chatbot.
2018-11-18
fanse29f7d45
I know this is old. But I say the same thing: Where is Gimbal Yaw Synchronous Follow on the M2P? I had it on the P4P and it really made a difference smoothing out the starts and stops of pans.
2019-9-23
