Two usb-c ports on Ronin Focus motor
1261 5 2023-7-10
Petar Varat
Flight distance : 2552 ft
Croatia
I have just one simple question:
Is there a reason or benefit why the Ronin rs3 pro focus motor has two USB-c ports?
Tnx
2023-7-10
DJI Wanda
Hello, there. If you are talking about the RS Focus Motor 2022. Two USB-C ports are used to combinate with DJI LiDAR accessories. When combined with DJI LiDAR, one port connects to DJI LiDAR, and the other is used to supply power.
2023-7-10
Petar Varat
Croatia
DJI Wanda Posted at 7-10 04:34
Thank you for your quick reply
2023-7-10
DJI Wanda
Petar Varat Posted at 7-10 10:36
You are most welcome.
2023-7-11
F.A.D.
is it also possible to attach the GPS module to the second USB-port on the focus motor? I'm asking as a RS2 user. It seems like you loop trough the middle port on the Ronin to the second port of the focus motor.
I would like to use the gps module and focus motor at the same time (attached to a car mount where the gps module is necessary).
Best regards,
David
2023-8-22
RoyEP3
Flight distance : 286017 ft
F.A.D. Posted at 2023-8-22 09:56
Did you ever figure out the answer to  this? I'm trying to do the same thing.
1-5 11:01
