Phanton 3 sta lost signal 80 meters!
2201 33 2016-11-11
harry0112
Flight distance : 167651 ft
Peru
Two weeks ago I have a problem with my phantom 3 standard, I eh flown and when I get to 80 meters distances the app starts to say lost signal and then returns home, I flew in rural areas to make sure that no no interference. I mind flying above 800 meters away and everything was fine. What's up? help me!!
2016-11-11
Have you tried to adjust the antenna when it starts to say signal lost?
Also what's the current firmware version?
2016-11-12
harry0112
Peru
DJI Mindy Posted at 2016-11-13 02:38
Also what's the current firm ...
yes i have upgrade my aricraft and of course i tried to move antenna when i was flying and same. lost signal and RTH. please i fly like i flew before and got 800 meters away with all ok
2016-11-13
harry0112 Posted at 2016-11-14 11:58
yes i have upgrade my aricraft and of course i tried to move antenna when i was flying and same. l ...
Did you update the firmware to 1.7.90?
Could you please try to go to another open field with little interference around and fly it again?
2016-11-13
Yusif
I agree after installing Im not getting signal at all, i installed firmware 3 times and still no signal
2016-11-13
DJI Natalia
Yusif Posted at 2016-11-14 13:15
I agree after installing Im not getting signal at all, i installed firmware 3 times and still no sig ...
Please check on "About" page for the current version firstly.
Have you tried to delete app and re-install it or change another mobile to connect it?
Also you could try to re-link them and fly it farther firstly then higher, please do not fly it straightly above your head.
2016-11-14
Ciro Italy
harry0112 what firmware you have ? if it is 1.6.8  there are issue .
you should upgrade to 1.7.9
2016-11-14
harry0112
Peru
Ciro Italy Posted at 2016-11-14 05:03
hi.. yes i did...new firmware. re link remote control, fly in rural zone, still it lost signal at 150 meters away.maybe i need downgrade. coz it worked good before this new firmware
2016-11-14
harry0112
Peru
DJI Mindy Posted at 2016-11-13 23:13
Could you please try to go to another open field with littl ...
i did. i flew and all is same. nothing. maybe i can downgrade. please. i cant to fly coz it RTH each time.
2016-11-14
jorgeeduardo84
Flight distance : 1343753 ft
Colombia
When I bought my DJI PHANTOM 3 STANDARD one month ago, I reached a distance of 600 Meters and an altitude of 450 Meters, but since 2 weeks ago I just could reached a distance of 130 Meters and an altitude of 110 Meters, and SIGNAL LOST and GO HOME. I checked DJI GO APP and BEGINNER MODE is DISABLE, MAXIMUM ALTITUDE is 400 METERS and DISTANCE LIMIT is DISABLE. My drone is on PERFECT CONDITIONS, I never have crashed and the FIRMWARE is UPDATED. So someboby could let me know what is happening.
2016-11-14
harry0112 Posted at 2016-11-14 21:36
i did. i flew and all is same. nothing. maybe i can downgrade. please. i cant to fly coz it RTH ea ...
You could try to downgrade the firmware to 1.6.80 by holding the academy-button in the DJI GO app.
2016-11-15
jorgeeduardo84 Posted at 2016-11-15 00:27
When I bought my DJI PHANTOM 3 STANDARD one month ago, I reached a distance of 600 Meters and an alt ...
Could you please clarify your current firmware version?
Have you tried to adjust the antenna when the signal starts to lost?
2016-11-15
harry0112
Peru
DJI Mindy Posted at 2016-11-15 06:09
i had 1.6.8 but i upgrade. and btw when i did it. it just take about 5 min . not like tutorial says. about 20 min. i did it wrong?
2016-11-15
harry0112
Peru
when i hold that botton, it says.
product: p3s
current version 1.7.90
get firmware version failet
select firmware version
---none---
i cant tap it
2016-11-15
harry0112
Peru
hi. i did. first i tried with 1.6.8 and i got 500 away  meters with some problemes. then i upgrade to 1.7.9 and i just got 250 away then RTH. i dont what i can do.
2016-11-15
harry0112
Peru
DJI Natalia Posted at 2016-11-14 03:11
Have you tried to delete app and re- ...
when i hold academy bottom it says "get firmware version failed"
i tried re instal firmware but it doesnt change.
2016-11-15
harry0112
Peru
i have this folder in my sd card check it on please maybe it have something wrong.
i still have the problem. i tried update with other phone but still. i cant fly
p3s folder
https://drive.google.com/file/d/ ... WM/view?usp=sharing
please help me
2016-11-17
harry0112
Peru
p3s folder
please help me
2016-11-17
harry0112 Posted at 2016-11-18 10:52
i still have th ...
Please try to find the update log file by following these steps:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-11-17
harry0112
Peru
DJI Mindy Posted at 2016-11-17 22:58
1. Enable Viewing hidden file ...
i have P3C_CAM_VERSION file in LOG folder. but it is not .tXT format. so i ask if there is some file that i need
2016-11-18
Nancy^^
Flight distance : 3481 ft
What about downgrade it manually.
This link may help.
http://forum.dji.com/thread-52777-1-1.html
2016-11-20
harry0112
Peru
i have a video where u will can to see my problem. look at DJI app. drone RTH. it is at 50 meter attitute. look at antenna position and look at where is my drone. it is exactly over me. i dont move anything i jsut cancel RTH. please help me
https://drive.google.com/open?id=0BxZN0CDcb4HhTmdmT2pNZnJySzg
2016-11-29
harry0112
Peru
2016-11-29
JpNL
Flight distance : 428245 ft
harry0112 Posted at 2016-11-29 21:48
i have a video where u will can to see my problem. look at DJI app. drone RTH. it is at 50 meter a ...
This is the worst scenario that you may have.
Antenna straight forward, and the drone right above you.
try to fly farther. and then go higher ..
and place the antenna 45 degrees..
You will see that the "signal lost" will disappeared..
2016-11-29
harry0112 Posted at 2016-11-30 04:48
Agree with JpNL, please follow his advice and keep us posted.
2016-11-29
DanD2
I have the same issue, flying it in the same location and the same way I used to.....This is my story....So after not being able to connect to my controller after the upgrade to 1.7.9, I eventually sent it out to STC Electronics in NY. I got it back late last week and finally flew it yesterday...WHAT A DISSAPOINTMENT!!! I used to easily be able to get to 400ft altitude at a distance of over 1500 feet away. I now LOSE remote signal near 300 - 350 feet altitude and cannot get over 1000 feet away. I should have left this darn thing ALONE. I don't know if my drone was at 1.5.7 or 1.6.8 before but it used to work flawlessly. Very disappointed. I want to downgrade it but am nervous because of the problems I had during my initial upgrade and don't want to be in a position to have to send it out again. $50 round trip shipping and $30 labor to fix......not happy!!!
2016-11-29
harry0112
Peru
DJI Mindy Posted at 2016-11-29 21:53
i did. i dont know how explain u. i did i tried move antenna, take it at 250 meters away but when i do it, drone stop many times and it make noise becaouse it stops abruptly i have another video
https://drive.google.com/file/d/ ... k0/view?usp=sharing
2016-11-30
harry0112
Peru
DanD2 Posted at 2016-11-29 22:25
I have the same issue, flying it in the same location and the same way I used to.....This is my stor ...
yes same problem. i did not upgrade or anything and i had that problem. if u get some solution. tell me please
2016-11-30
harry0112 Posted at 2016-11-30 22:48
i did. i dont know how explain u. i did i tried move antenna, take it at 250 meters away but when  ...
If you had adjusted the antenna, maybe you ran into interference in that area.
Please try to fly in another open area to see if you get the same distance.
2016-11-30
harry0112
Peru
DJI Mindy Posted at 2016-12-1 01:56
Please try to fly i ...
i told u already. i did 4 places with the same problem. when will u release next firmware. maybe it will fix it
2016-12-1
fans68a64d63
Flight distance : 189203 ft
I hope I never have these issues. Mines worked flawlessly since day 1!!
2016-12-1
harry0112 Posted at 2016-12-1 22:29
i told u already. i did 4 places with the same problem. when will u release next firmware. maybe i ...
If still no improvement, you can contact our tech support at support.us@dji.com and send it in for further evaluation.
2016-12-1
jocass
Flight distance : 61588 ft
Portugal
jorgeeduardo84 Posted at 2016-11-14 16:27
My friend, i have the same problem (i live in europe). The problem is the Phantom 3S, it's a piece of crap, and DJI knows that. The scariest thing is that there seems to be no solution. My P3S is currently under warranty to be repaired for the 2nd time and I will not give up complaining until they solve the problem. Forget what they tell you to do, the problem is on the Drone.
2016-12-2
harry0112
Peru
jocass Posted at 2016-12-2 17:25
yes i am agree. but what can we do? maybe next firmware fix it? but do you know ? when it will be availible? and if there will ...now i sent it to me seller here in PERU. they change drone's antennas if after it doesnt work. they dont know what more they can do. DJI should do something. a lot opf people has the same issue. and they just say update firmware, relink RC, try different places, etc etc. to me they did it coz they just want sell the PHANTOM 4 or this new PHANTOM 4 PRO.
2016-12-12
