P4p camera will not focus.
1912 19 2016-12-24
fans304933e2
Flight distance : 153743 ft
Just got my p4p and did firmware update on aircraft and rc. First day video and stills focus was perfect. However after that next 2 flight days Focus would not work for Stills and video. Tried to focus manually and that didn't work either. Half pressed shutter release got beep beep green box indicating Focus took photo was horribly out of focus. It appears that it will not adjust focus for me. Any advice or help would be greatly appreciated.
2016-12-24
HellStream
Flight distance : 1370771 ft
Finland
Try to calibrate the camera/lens again. You are able to do it form the settings.
2016-12-24
The image you posted is too small to tell if it is focussed or not
2016-12-24
fans304933e2
Sorry hope this one's better. Someone recommended calibrating the camera. Can't find that in settings. Funny thing was that it worked perfect day 1 but not since then. Still looking for good advice. Thanks
2016-12-24
fans304933e2 Posted at 2016-12-25 09:55
It's also too small and an image shot indoors of a subject two metres away is not the way to test an aeril camera.
To add a larger photo you may have to click on the Advanced icon (centre right of the box you post in).
2016-12-24
fans304933e2
Thanks for posting back so quickly and trying to help. Didn't see the advanced icon near the comment section. But here's one I shot outside. While flying.
2016-12-24
fans304933e2
This is one I took the first day when the focus was working normal. Like a regular SLR. Now I can't get it to autofocus at all. Both video and photos look out of focus.
2016-12-24
This is how to attach a picture so it shows as more than a thumbnail.
2016-12-24
fans304933e2
Hope this works. As I said everything was fine on day 1, was able to auto focus and get great images. Now when I use auto focus the image on the screen does not focus. Checked App version 4.0.1 ,  version 01.01.0203  ,  RC 01.03.00.00     . IMU was calibrated. Would like to hear its something I did and can fix. Also just want say thanks for your patience and help.
Day 1 nice
Day 1 nice
Day 2
Day 2
screen shot today
screen shot today
2016-12-25
ErC...
I have also encouter the same problem on the first day of flight, however the second day got better. But still dont know how to fix or control it. Really hope someone can help.
2016-12-26
fans304933e2
ErC... Posted at 2016-12-26 21:09
Sorry to hear that yours had the same problem as mine. However yesterday out of the blue it starts working again and I'm not sure why or how. concerned that it wont last and the problem will resurface. Keep me posted on your situation. please.
2016-12-27
fans676e19e6
Flight distance : 50840 ft
I'm having the same issue and I'm afraid it's hardware related.  Auto focus doesn't work and neither does manual focus.  It's all just looks horribly blurry.  When I tap to focus it gives me a green box for a second and then the box turns red.  Any ideas?
2016-12-27
DJI-Jamie
Flight distance : 112405 ft
fans304933e2 Posted at 2016-12-28 00:46
Just to clarify, you only noticed this after a firmware update and not prior? Have you tried restoring the unit to factory settings via the Assistant 2 software?
2016-12-27
ErC...
DJI-Jamie Posted at 2016-12-28 13:00
I did the update prior my first flight therefore I don't know what its supposed to be. It only happened to me on the first day. The second and third time i flew was working fine.
2016-12-28
DJI-Jamie
ErC... Posted at 2016-12-28 22:01
Just to make sure, you didn't try the restore to factory option via the Assistant 2, right?
2016-12-28
DJI-Jamie
fans676e19e6 Posted at 2016-12-28 11:05
Have you tried connecting the unit to the Assistant 2 software and restoring to factory settings? It wouldn't reset the firmware, but ensure that there aren't any odd presets that could be affecting the unit.
2016-12-28
ErC...
DJI-Jamie Posted at 2016-12-29 06:11
No, because I didn't encounter any problems after my first flight. If it happens, I will try to restore it. Thanks!
2016-12-28
ErC...
I wonder if anyone would try to restore it and fix the problem. Please let us know if it works.
2016-12-28
DJI-Jamie
ErC... Posted at 2016-12-29 07:44
It never hurts to try, doing a restore, it has never led to any negative effects that I've been made aware of (knock on wood ). Let me know if the issue does come back, though.
2016-12-28
fans676e19e6
I did restore to factory settings and had no luck at all.
2016-12-28
