Litchi App Compass Calibration
6857 13 2017-2-20
AH!
Installed Litchi yesterday, went to test fly today the Mavic with it but I'm getting an error code when trying to calibrate the compass.
Has anyone else had this issue or know how rectify?
"Failed to start compass calibration.  Reason: Setting parameters operation failed. (code:-1007)"
Litchi Compass Calibration Error
2017-2-20
DroneFlying
Flight distance : 10774613 ft
I haven't and don't, sorry, but have you tried doing the calibration using DJI Go instead?
2017-2-20
AH!
DroneFlying Posted at 2017-2-20 04:57
Yes thanks, works fine with DJI Go app.
2017-2-20
The Rev
Flight distance : 1256837 ft
AH! Posted at 2017-2-20 05:32
If its fine in DJI Go 4 it should be fine in Litchi so I would delete the app and reinstall
2017-2-20
EdM
Flight distance : 1491814 ft
If you have calibrated in with DJI Go, why do you want to calibrate it again?
2017-2-20
MavicP
Flight distance : 20161 ft
Wandering if The Magic orientation indicator, i.e. green arrow on the FPV view, is associated to the campass calibration. Mine arrow is much off.
2017-5-27
Flight distance : 10186312 ft
MavicP Posted at 2017-5-27 09:11
If your arrow is not pointing in same direction as aircraft you have a problem.
2017-5-27
If you start your Aircraft in the dji go app and your compass checks out it's ok, just check before you take off that small arrow is pointing same way as your aircraft.
2017-5-27
MavicP
hallmark007 Posted at 2017-5-27 09:18
Thank you for the advice!
Using DJI GO 4 APP, there is no issue. When using Litchi APP with goggle, the little arrow underneath the normal view does not point to the same direction as the Mavic, or behave funny when changing the Mavic direction. Any idea on how to fix it? Thanks.
2017-6-3
MavicP Posted at 2017-6-3 08:55
I think this is a problem with the litchi app I read on there Facebook page others having same problem and litchi are supposed to be fixing it in a further update.
2017-6-3
MavicP
hallmark007 Posted at 2017-6-3 09:25
Thank you for the info. Will wait till Litchi to fix it. Have a great day!
2017-6-3
WolfgangStiller
Flight distance : 599416 ft
MavicP Posted at 2017-6-3 10:00
No need to wait on Litchi to fix it, just do it in DJI Go4 (but I suspect you already knew that).
2017-6-3
MavicP
WolfgangStiller Posted at 2017-6-3 10:57
Yeah, both Apps are ok. Just hope Litchie will fix this little, but nice-to-have, feature.
2017-6-4
WolfgangStiller
MavicP Posted at 2017-6-4 09:50
I'd expect it to be fixed. I have found them very responsive to fixing any issues which pop up.
2017-6-4
