MavicP Posted at 2017-5-27 09:11
Wandering if The Magic orientation indicator, i.e. green arrow on the FPV view, is associated to the campass calibration. Mine arrow is much off.
If your arrow is not pointing in same direction as aircraft you have a problem.
If you start your Aircraft in the dji go app and your compass checks out it's ok, just check before you take off that small arrow is pointing same way as your aircraft.
hallmark007 Posted at 2017-5-27 09:18
Thank you for the advice!
Using DJI GO 4 APP, there is no issue. When using Litchi APP with goggle, the little arrow underneath the normal view does not point to the same direction as the Mavic, or behave funny when changing the Mavic direction. Any idea on how to fix it? Thanks.
MavicP Posted at 2017-6-3 08:55
I think this is a problem with the litchi app I read on there Facebook page others having same problem and litchi are supposed to be fixing it in a further update.
hallmark007 Posted at 2017-6-3 09:25
Thank you for the info. Will wait till Litchi to fix it. Have a great day!
