fansb9972bfd
Flight distance : 7146 ft
fans5b2f68be Posted at 2017-9-7 23:13
I have the same problem.
How do I "clean the cache data in APP first" as you suggest?In DJI Go 4, I can't do anything because it starts asking for the Chinese phonenumber.
I also looked in DJI Assistant 2 but didn't see any option.
It really looks that you cannot do anything, but in fact, if you try to slide your touchscreen, you should come to some operating system controls and be able to get somewhere else. With my Phantom 4 Pro+ (no smartphone, built in Android-based device, like "a smartphone without functionality of a phone") I could get to the systems settings and reset the controller to the factory settings there, which solved the issue, supposedly caused by using the flight simulator, which seems to make the controller to believe it is in China. I even managed to find the way out of the "Give me a Chinese phone number" quickly, because I've already spent hours on figuring out "how to log in DJI account after logout, which for whatever reason, turns Wi-Fi off and the subsequent log in prompt seems to block the whole device while it is not possible to login due to missing internet connection" (same principle of sliding touchscreen to get some OS controls, which is not obvious for the beginners). |
