Mabou2
Flight distance : 811257 ft
Several months ago, I had a terrifying near miss with my drone vs a manned airplane... This story is a GREAT example of why we should be forced to learn the rules and pass a test before we are allowed to fly.
I was flying in a safe, non-restricted air space. There was low cloud cover, but otherwise clear flight with no wind or turbulence. I was shooting a retail location for a client. I had been shooting at various heights for an hour, and decided to send the bird up to about 600' to get a wider shot of the area. Suddenly, there was an explosion of sound as a Hawker private jet appeared out of nowhere at low altitude, and on an intersecting path with my drone. After a second of trying to figure out what to do, I decided my best action was to freeze the drone in place. I had no idea if my drone and the plane were at the same altitude, I couldn't tell in that split second whether the Hawker was ascending, descending... I just knew that it was heading in the vicinity of my drone. My knee jerk reaction was to let go of the controls, to keep the drone in one place (making it as small a footprint as possible, and to increase the chance that the pilot might see the drone if it is in his path (rather than accidentally dropping into his path at the last second). In those two or three seconds, I was terrified and at the last second I realized that the Hawker was on a direct intercept with my drone.... IT FLEW DIRECTLY UNDER MY DRONE, blocking my view of the drone for a split second as it passed by.
Horrifying, absolutely horrifying.
I immediately landed and didn't fly again for days and days, I was so shaken up by what had happened.
Since I have been taking my Part 107, I have a much better understanding of why that occurred, and it relates directly to the ceiling of cloud cover.
Are you aware that you are required to research what the elevation of cloud cover is before you fly? Are you aware that you are not allowed to fly within 500' vertically of that cloud cover? Are you aware that you are not allowed to fly within 2000' horizontally of that cloud cover?
So on the day of the near accident, the cloud cover was low, probably about 800 feet or so. This meant that the public air space that I was legally able to fly would be reduced to 300' maximum, since the 500' beneath the clouds is now reserved for manned aircraft. SO, legally speaking, since the cloud cover was low, as soon as I went above 300', I was flying in space strictly reserved for manned airplanes.
I took a chance by flying higher than 400' for a few minutes, but I had been flying for an hour without a single sighting or sound of manned aircraft. I was well outside of any 5 mile radius of any airport. But I didn't know about the rules for flight in the presence of low cloud cover. So suddenly a random event occurred where a jet appeared low in the sky, staying under the clouds himself.
This is only ONE example of why we, as a community, need to learn what the heck we are doing. I could have brought down a 40 million dollar jet with at least one person on board, because I didn't know the rules and etiquette of flying in a low cloud situation. And since I didn't own (or even know I should own) and ATC radio, I got no advance warning at all about an approaching jet.
Matt
