hallmark007
Flight distance : 10017858 ft
mkaiserco Posted at 2017-7-16 12:57
Sorry, I did upload it to phantomhelp but didn't know what to do from there. Here's a link. to the result . . . http://www.phantomhelp.com/LogViewer/ADC766KS5O5W5V4JQLTB/
Is that what you need?
Yeah that's it, you don't mention if it was phone or RC you were using , so guessing by your log it was phone. You lost signal twice, but your aircraft did what it was supposed to do. Within 20 meters if you loose radio signal for 20 seconds your aircraft will RTH hover at .3 meter and wait for your signal to land.
Why you lost signal, many things can cause this high usage in your area , position of antenna i.e. Should be vertical unless AC is directly overhead if this is the case then horizontal is the best place to receive signal.
I don't think there is anything wrong with your AC but you should get dji to check you log, you could always PM a mod here she/he will organise for you.
I would go to a different area and see if signal improves.
Good luck. |
