AnticipateMedia
Flight distance : 309626 ft
It's definitely something to do with the shim in the t-joint. I had gone in and added some shim to both joints to remove any wobble, but frankly that made the jello far worse. I removed them and brought one side back to factory, and the other, which was still very loose, I added a little silicone. It still has a little wobble, but matches the other side now.
Lo and behold when I flew... no jello. I was at 50-80 shutter, but still. Slow motion view at 240fps shows no weird vibration. The other things I did was revert back to the original suspension balls from the stiffer ones included, flew in warmer temps (about 40 F), and changed to the new quick release props. I have more testing to do in heavier wind, but it looked fine so far.
The only noticeable jello I saw before was when the body was perpendicular to the wind and the shutter high. |
