[after update] Move forward and suddenly slow down
1766 10 2017-7-23
fans09cbcaee
Flight distance : 112805 ft
Singapore
Dear friends,
After update P4 (5 days ago) aircraft and main controller, when I move forward and reach 30 kph it slow down do 0 kph and again move forward to 30kph and goes to stop, I don't know why. It never happened to me before upgrade.Today I was about 100 meters altitude (with no obstacles around me) and it slow down even if I pushing stick on the controller max forward continuosly.
It only happened in normal mode (GPS), Point Of Interest worked fine.
Does option "Enable obstacle avoidance" is turned on by default? Also obstacle avoidance in tapfly and activetrack?? I forgot...
Identical problem
After update, the motors after start are rotating slower before I fly, is that correct?
Is there an option to downgrade firmware?
Best regards
2017-7-23
Blériot53
Flight distance : 6188465 ft
It looks as though the obstacle avoidance is seeing the hill ahead as an obstacle and is slowing to avoid it?     As to downgrading the firmware, if what one reads on the forum here, that is no longer an option.
2017-7-23
fans09cbcaee
Singapore
Thank You for Your answer
Like I said:
" I was about 100 meters altitude (with no obstacles around me) and it slow down even if I pushing stick on the controller max forward continuosly."
There was no any hill or trees etc. in front of me.
This is my video from first flight after upgrade firmware, You can see, it slow down when it gets speed.
Please help
2017-7-23
DJI Thor
Flight distance : 13602 ft
Sorry for the inconvenience. Just to verify, did you get any messages on the app? Or did you mount propellers protector?
Please try to check is there any dirt on the Obstacle Avoidance System and calibrate the vision positioning system via DJI Assistant 2.
Here's the calibrating tutorial for your reference:
2017-7-24
Cetacean
Flight distance : 2528264 ft
fans09cbcaee Posted at 2017-7-23 14:25
Aloha fans09,
     After you try Thor's suggestion to calibrate the VPS, see if that helps.  If it does not help try this;
"In firmware v02.00.0106 I also have tripod function but not test it because stop flying after first 10 minutes of very unstable/shaking flight. In one moment my drone just be near to make flip. Also I find that all motors get very hot during shaking and rr-rr-rr sound. After downgrade to 01.02.0602 all problems with shaking and motor rpm disappear and P4 very stabile."
     Hope this helps!
Aloha and Drone On!
2017-7-24
fans09cbcaee
Singapore
Hey guys!
After update, the motors are more hotter, I forgot to mention it.
I won't downgrade firmware using outside programs, It could be an option to downgrade to the previous firmware if this version is not stable and everyone knows about It but You DJI won't hear us, we are Your customer. We spend money for useless drone (after update 02.00.0106).
Thor, You didnt tested this firmware, Am I right? People are furious for this unstable flying and shaking aircraft (!), I need to resign wedding day in next week due to unstable and slowing down speed... Thank You so much.
There is no any dirt in obstacle sensor etc. Everything works fine before update. I prefer stable drone than Tripod and other functions.
2017-7-24
fans09cbcaee
Singapore
I didnt get any warning messages on the App before start and during slow down. Also I didnt install any propellers protector.
2017-7-24
Aardvark
Flight distance : 384432 ft
fans09cbcaee Posted at 2017-7-24 01:19
Hey guys!
Have you calibrated the VPS sensors as suggested above ? This has been know to solve similar problems previously.
My personal preference is to do all calibrations after a firmware update. Surely any previously saved values would be over-written by update (but I could be wrong).
2017-7-24
fans09cbcaee
Singapore
"Surely any previously saved values would be over-written by update (but I could be wrong). "
In previous upd I didn't calibrated sensors - they works properly. I will calibrate and write post here.
My P4 also shaking when I landing (from 10-15 m above ground) it shakes like my gf ass.
2017-7-24
fans39704101
Flight distance : 265830 ft
I have the same issue as this and I'm 250' in the air with nothing around me, you can see the speed on the display go between 12 and 8 and 9 and 10 and 12 and 9 and 6 and 8 and it keeps going back and forth like this. Had no issues what so ever before the upgrade and now its doing this. I did the calibration as well (now raining outside) but honestly I don't expect that to be the fix at 250' in the air with nothing around me.
2017-7-24
Jamie 54
Flight distance : 498688 ft
My drone does the exact same thing after the update.  Flies good and then stops. I have reinstalled the firmware and have calibrated the sensors, I have also notice the motors seem to be hotter then they use to be.  Going to try and refresh the software again to see if third time is the charm .
2017-7-24
