Record in 4K, but stores on phone in 720p
8040 11 2017-8-7
ToonTonic
Flight distance : 47359 ft
Hi all
As the title says, I only really record in 4K (not UHD). I note that on my Samsung S7 Edge that the footage stores as 720p but when removing the SD card from the Mavic, the same footage is full 4K as intended.
Im pretty sure theres a logical explanation to this, im just not having luck finding it.
Its adding alot to my already very stressful attitude towards this DJI Go app on Android.
Many thanks to any replies
2017-8-7
DJI Joe
The video that streams from your aircraft to your device is only 1080p maximum (depending on settings). Any glitches and interruptions in connection will be visible on this video stream. For the actual content recorded in full res and not affected by Occusync connection, you will be grabbing the footage off your SD card.
2017-8-7
StianGel
Flight distance : 686654 ft
Norway
There is limited bandwith in the live view.
That is why you only get the 720p on the phone.
2017-8-7
idofuel
Flight distance : 476768 ft
actually a great feature if you think about it...I download from the card to get full quality and just use the cache files for intention of quick view so it doesn't hog up the device storage
2017-8-7
dancopter
Flight distance : 17901030 ft
United Arab Emirates
Trying to transmit live 4K footage at 60 mbps over several kilometres is asking for alot!
2017-8-7
ephektz
Flight distance : 94534 ft
Fire up your Mavic and connect as usual, as if for a flight. Open up DJI Go 4.
Click Editor.
Go to the video you want. Click it.
Click Download Original.
Even easier: pull the SD card from your Mavic and get the video from there.
2017-8-7
ToonTonic
Spot on folks.
Wasnt expecting 4k from mavic whilst in flight, just pondered why its only 720p.
Ill continue to keep pulling direct from the SD card
2017-8-8
Bekaru Tree
Flight distance : 15513100 ft
South Africa
thanks for the question - helps me out too.
2017-8-9
Mari
Flight distance : 1308780 ft
ephektz Posted at 2017-8-7 20:12
Click Editor.
This doesn't work for 2.7 or 4K... you have to connect via USB or pull the SD-Card from the mavic... files are very big and wireless transfer will take very long time, therefore use cable or put SD-Card in computer...
2017-8-9
ghostrdr
Flight distance : 1272723 ft
Mari Posted at 2017-8-9 11:48
I can download 2.7K wireless on my iPad Air2, I cannot download greater than 1080p on my iPhone 6 Plus. It seems to vary by device. I never record in 4K since I don't have a computer that can handle it.
2017-8-9
ephektz
Works fine for me on my iPad Pro. No problems whatsoever. I agree though, the way to do it is by either plugging the Mavic into the computer or yanking the SD card.
2017-8-9
kosmelnikov
Flight distance : 634098 ft
With Sync for DJI app even large files can be useful on phone. The app has Trim before download feature that allows download only the best moments of video. The app available on iOS or Android.
2019-9-26
