Connection cuts in and out
730 8 2017-8-30
sethd
My drone will fly fine for a little bit then it will suddenly lose connection to the controller and return home. It will get within 50 feet and still say no signal and then will suddenly  reconnect. It is a refurb unit so i dont know if there is something wrong in the drone or not, I replaced the antenna and it still did not fix it. any help is appreciated
2017-8-30
fansf4ea8bf4
Same thing here. Just started with last update. Anyone else have this issue or a fix?
2017-8-30
ALABAMA
Flight distance : 10442687 ft
Read around on the threads.      log out, then back in.
2017-8-30
DJI Diana
Flight distance : 2408 ft
Just to verify, which drone are you referring to?
2017-8-30
sethd
DJI Diana Posted at 2017-8-30 21:02
phantom 3 standard
2017-8-31
G_Sig
Flight distance : 9109311 ft
Iceland
What  phone or tablet do you use?  Have you set it to airplane mode?
2017-8-31
DJI Diana
Have you tried to fly it in different open areas? Besides, is the firmware up to date? Like G_Sig mentioned, enable the airplane mode on your phone, please try different mobile device if it is possible.
2017-9-2
tnflyer53
Flight distance : 215837 ft
I seem to be having similar issues.  Latest firmware and Go app, Phantom 3 Std, Sammung Galaxy S6, Airplane mode on, and flown in different locations. I'll have good signal strength and then app just cuts off. I can reconnect after logging back in, but generally lose any video or pictures that were taken before incident.
2017-9-2
sethd
DJI Diana Posted at 2017-9-2 02:07
everything is up to date and I use a galaxy s7, it is on the supported phones list with DJI
2017-9-3
