Why does my top altitude not show in my overall stats?
1750 12 2017-9-11
Ammpexx
Flight distance : 1879495 ft
Hi everyone,
I am wondering about my overall flight stats: flight time, number of flights, travelled distance, etc. they all seem to be fine. What's not okay is the maximum altitude. It's stuck at a random value (80something meters), but right below in the stats of the individual flights is a flight with e.g. over 150m altitude.
Anyone else experience this?
2017-9-11
Wachtberger
Flight distance : 261509 ft
The same had puzzled me as well in the beginning. It has then been explained to me that this value does not indicate the top altitude you have been flying at, but the highest altitude you have been taking off from.
2017-9-11
Ammpexx
okay that makes sense... in a way :-) thanks for the enlightenment.
2017-9-11
scorpionro
Flight distance : 211355 ft
In DJI GO 4, version 4.1.9 on iOS they actually call it MAX TAKEOFF ALTITUDE. Not sure how it was called before as I'm a fairly new user.
2017-9-11
Ammpexx
scorpionro Posted at 2017-9-11 02:02
So the question was raised often enough by now :-) well we'll see, when the update for Android follows.
2017-9-11
Wachtberger
Don't expect too much from the next update in this regard. Android 4.1.8 and iOS 4.1.9 versions were launched at the same time, both being the latest versions. It's just different programmers, using different words...
2017-9-11
DJI Thor
Flight distance : 13602 ft
Could you please provide us with the screenshots of it? Thank you.
2017-9-11
Ammpexx
DJI Thor Posted at 2017-9-11 02:22
Who, me? With the strange Android version or the iOS-Version?
2017-9-11
Ammpexx
well anyway here's Android
2017-9-11
Gulfu
Flight distance : 771240 ft
India
Ammpexx Posted at 2017-9-11 03:23
Its not the top altitude  .. its Top altitude you took off
2017-9-11
DJI Thor
Yes, like Gulfu mentioned, it is the max takeoff altitude, not the max altitude of your flight. If it is still wrong, please let me know. Thanks.
2017-9-12
fans9ea9c44f
Flight distance : 22129 ft
Well I've aired this. Even if it is the max take of alt., mine says 600 m which is way higher than where  I live . I 've so far only flown here and 10 miles away which is nearly same height. On the  it logged it, I only made one
Short gesture controlled test flight.
I sent screen shot but answer was read instructions.
Doesn't seem to be causing any other problems.
2017-9-12
fans9ea9c44f
Please read 602 ft , not metres, my mistake. The height above msl where I flew was 400 or so feet. But with only 30 ft or so altitude.
It's  not a big deal, but I'd like to reset it .
Don't think it causes other problems, so I live with it.
2017-9-12
