Geebax
RicardoGray Posted at 2017-9-15 20:44
I'm just stating my opinion here, but something was wrong. I have replaced motors on my own P3A and several other units and never had an issue. If you are positive the wires were connected correctly, I wonder if the motors were good to begin with. I don't see how the ESC's would smoke a motor that is wired correctly. These are very sensitive controllers and the slightest deviation or feedback from the motors would signal an error I would think. Although I have not worked on a P4, only P3 standard and Advanced & pro. I may be wrong but I would double check everything before you install a new board. Good luck!
I agree with RicardoGray, something was wrong with the motors I suspect. If the aircraft flew, then the wiring was correct. And the same applies to the ESCs, if it flew, then they should be OK. |
