Samsung Note 8 & DJI Spark
4711 15 2017-9-24
Euro7r
Got a new phone (Samsung Note 8 running 7.1.1 Nougat) and running 4.18 DJI App.
Everytime I connect the usb cable from the controller to my phone, it says it's "USB charging connected device".  I've turned on usb debugging and MTP as this setting worked on my old phone.
So my issue is that it's using my phone to charge the controller via the usb cable and won't connect to the phone to utilize the app.  On top of this, it somehow shuts down my phone out of no where after I play around with the settings.
I'm lost on what the issue is right now.  Might just have to use my backup phone for drone flying purposes...
2017-9-24
DJI Elektra
Euro, did you try to connect your phone with RC through WIFI? Please keep us updated, thanks.
2017-9-24
lannes
Flight distance : 4465 ft
If you haven't go the right type of "data" cable , OTG won't work, you can't just use any type of USB cable otherwise you will get just charging
2017-9-24
Euro7r
lannes Posted at 2017-9-24 19:24
It's the same cable that came with the Spark, used to charge the RC controller.  When I use my old phone, everything works normal, so I have no idea what's the issue with my new phone.
2017-9-26
Euro7r
DJI Elektra Posted at 2017-9-24 19:09
Nope, I am going to give that a try this coming weekend and see if I can isolate what this could be.  Thanks
2017-9-26
Its_Big_Dee
Flight distance : 266024 ft
I too just got a note 8 the video was very glitchy and loses signal over Wi-Fi. I tried the otg and it works fine but the app has crashed a couple of times.  I'll probably stick with my iPhone to fly
2017-9-26
DJI Elektra
Its_Big_Dee Posted at 2017-9-26 19:50
Please use the device in our recommended list. Did you lost your signal when you use Iphone? You can try to reset the wifi of drone or RC and see if it can work better. Press the power button for 9 seconds and you will hear 3 beeps to finish the reset of RC.
2017-9-27
Its_Big_Dee
DJI Elektra Posted at 2017-9-27 01:21
https://www.youtube.com/watch?v=MwAVJSbO8Ek
The only time I lose signal with my iPhone is when I get far out on distance. With my note 8 over WiFi it’ll lose signal with it 8ft in front of me
2017-10-6
brezilla
Flight distance : 1198 ft
Serbia
Try different OTG cable and worth mentioning that OTG end should be connected to RC.
2017-10-8
DJI Elektra
Its_Big_Dee Posted at 2017-10-6 03:32
Sorry to tell you that note 8 is not in the recommended list. Please use your IPhone to fly your spark for better flight performance. Thanks for your support.
2017-10-11
Its_Big_Dee
DJI Elektra Posted at 2017-10-11 22:51
Sorry to tell you that note 8 is not in the recommended list. Please use IPhone to fly your spark. Thanks for your support.
When will they get support for the note 8 it's the new thing out
2017-10-22
fans88a891a9
Flight distance : 8274 ft
Mexico
try a different way to use the OTG , here is what work for me
2017-11-1
fans88a891a9
Mexico
fans88a891a9 Posted at 2017-11-1 14:25
1.- Turn On Tx
2.-Turn On  AC
3.- Wait until solid led green on the TX
4.- Connect OTG cable to TX
5.- Connect USB to phone
6.- Maybe you will be prompted to choose the app to use , choose the dji go 4
Let us know what happen please,
2017-11-1
FreddieMoD
JDI doesn't support the Note 8 for otg cable use?
2017-12-22
DJI_
Why dont you guys put an iphone inside the box where the Drone comes, ... so i have to buy an Iphone in order to Fly your product? what is this about?
2018-1-4
djiuser_6cWEhp5
Flight distance : 15922 ft
Following this thread...I too use a Samsung Note 8.
I originally purchased the Spark alone and was able to get it working with my Note 8. However, due to another issue, I returned it and picked up a Fly more combo with the TX thinking it would be the same. I fought with the setup for most of the day. The phone would NEVER connect. I finally figured out that if you put the phone in Airplane mode and then turned on the Wi-Fi, it would finally connect...at least for a while. But if the other radios in the phone were on, the phone would never get connected. I'm still not even sure if it got Activated...I assume it did as it finally shows connected. But I have to link the quad with the controller every time.
Coming from another manufacturer that had full support for the Note 8, I'm a little surprised and disappointed that DJI does not. Since the Samsung line is the most popular Android, and since DJI has support for Google Android, I assumed the Note 8 would be supported. I'm to see it is not.
2018-1-28
