Punchbuggy
Flight distance : 483166 ft
The IMU error is a known problem which I thought was fixed in one of the most recent GO updates, but obviously not. Ignore it - unless the status continues to report that one is necessary after the P4 has warmed up.
The current firmware has issues which DJI have acknowledged. They are working on an update, although ETA is unknown.
I note you have an iPad Mini 2. Expect video transmission break-up when flying your P4. The CPU is under-powered to handle the video decoding load with the 4.1.x series of GO. You'll need a A8 or higher CPU for faultless in-flight images. The Mini 2 doesn't have this problem running Litchi, and it may be a cheaper investment than an iPad upgrade. |
