poppylfh-sp
Flight distance : 3902884 ft
I hadn't flown P4 for awhile, been having too much fun flying Mavic. So I started everything and was going ok, after normal startup, got message that needed RC and aircraft firmware update. RC firmware update appeared to go ok with download and update then got message to connect aircraft to RC for aircraft firmware update and it would not connect and then the RC went haywire. Got what I think is light blue status light and 2 solid RC battery lights, it will shutdown with normal press and then press and hold but on startup right after initial press it goes to the 2 battery light and light blue status light. I did a successful aircraft firmware update using Assistant 2 but still having same issues with RC. I've tried both recommended RC reset procedures, holding C1, C2, Record & Camera wheel while doing startup and shutdown, also C1, C2 & Shutter but won't reset. Suspect only recourse is send in for repair but hoping something I haven't tried to reset it and get it working. I have also left RC on until no battery and trying recharge from there but not getting proper recharge light sequence and is seemingly not recharging properly. Any ideas will be appreciated.
