BudWalker
Flight distance : 5966247 ft
DroneFlying and I both looked at this flight. He may have some additional observations, and possibly a different analysis. FLY022.DAT has two flights, the second with the incident you described. The second flight was also contained in the .txt file you submitted. IMHO the incident was caused by flying location that had several sources causing geomagnetic distortion. In fact, there were so many I was unable to really get a clear picture.
With the first launch there was Yaw/magYaw separation which was then followed by the Mavic rotating while holding the Yaw value constant. This is a sure indication that the launch site was geomagnetically distorted.
The real story here is the magMod value. Prior to the first flight it was 1800 but got as low as 300 during the first flight. After the first flight the Mavic was then moved a very short distance and launched without incident. However the magMod value was 1000. Towards the end of the 2nd flight the magMod value got as high as 2200. This is particularly interesting because as the Mavic was circling there was one particular spot where the magMod hit a max each time it passed that spot. Look at attach 2 and 3.
From the Google Earth image it looks like you were flying in an area that would have a lot of ferrous material. My advice would be not to fly here. Good luck.
