Keule
Flight distance : 3733015 ft
I would use Autopilot.
On one side of the building you create for example 4 waypoints. (depending on the width of the building and your FOV)
On waypoint #1 you define waypoint actions. such as climb 5m and take photo. So, adding 20 actions to your waypoint #1 as described before, you cover 100m height.
For your next waypoint (#2) which is, say, 10 m to the left, do the same, except you are descending now 5m and take a photo on each action.
Repeat the procedure until you have one side covered.
For the other sides, you just move the anchor point of your mission and start. That's it.
Best regards,
K.
