DJI GO 4.1.14 Problem
3072 39 2017-10-26
Albatros24
Flight distance : 116010 ft
Good evening,
I just made the update to 4.1.14 and I have at least one problem: My flight recordings no longer contain the "traces" of the Mavic ... Moreover if I ask the display of the base map, the app crashes! Do you have these problems? (iOS 10.3 / iPhone 6s +) Thank you and good evening. PS: Do you know if we can go back to 4.1.12? (I had no problem with) Thank you.
2017-10-26
fans61699a75
Flight distance : 24897940 ft
Try uninstall the app and reinstall
2017-10-26
Ex Machina
Flight distance : 1806362 ft
By "traces" do you mean the flight data overlay? If so, you just need to turn Video Titles back on in the camera prefs. App and firmware updates often require one to reconfigure app settings.
2017-10-26
ro_flyer
Flight distance : 7557283 ft
Brazil
Almost the same issue here. I can see the Mavic "traces" but only in the normal map view, when I try to change for the satellite or Hybrid views the app crashes. (iOS 11.1 beta 5 / iPhone7).
In iOS there is no way to go back to previous versions since the app store only shows the most recent app versions. Maybe if you hav a backup of your phone in iCloud or iTunes you can restore the phone to a earlier point in time where the previous app version was installed...
2017-10-26
Albatros24
@Ex Machina the movement curve of the Mavic... Difficult in english !
@fans61699a75 : Already done !
@ro_flyer : Thank you for this infos !
I regret my 4.1.12 !
2017-10-26
HyLenz
Flight distance : 1848182 ft
The overlay is there but VERY faint for me on both devices. Also verified app crash switching map to sat or hybrid while replaying recorded flights on both iPhone 6s IOS 11.0.3, and iPad Mini 2 IOS 11.1 Beta 5...
2017-10-26
ro_flyer
Brazil
HyLenz Posted at 2017-10-26 11:42
Exact same issue here....
iOS is in 4.1.14 ... and they managed to ruin flight records function...  4.1.10 on iOS have lagging problems and the 4.1.0 had a bug with Find my Drone function always pointing to China.... I wouldn't be so anxious for new (broken) app versions....
2017-10-26
Albatros24
@HyLenz : YES !  You are right, it is very very weak !
2017-10-26
ro_flyer
Brazil
Just tested in both iPad Mini 4 and iPhone 7 the same problem happens:
APP  crashing when switching flight record map views from normal to satellite or hybrid...
2017-10-26
ro_flyer
Brazil
I CAN SEE A DJI MODERATOR SAYING:
WAIT PATIENTLY WHILE OUR ENGINEERS WORK ON THIS ISSUE. IT WIL BE SOLVED  IN A NEW APP VERSION TO BE RELEASED SHORTLY.
4.1.15 HERE WE GO!!
2017-10-26
Albatros24
It's certain !
If there is ONLY THAT as a bug, it's not very serious ... But ???
2017-10-26
Jyunte
Flight distance : 2103150 ft
ro_flyer Posted at 2017-10-26 11:59
Yes, I can also confirm that displaying a flight log and switching to satellite map display causes the app to crash.
2017-10-26
Locoman
Flight distance : 748675 ft
just delete and reinstalled the GO4 4.1.14. Still the same issue with the flight log. It shows up but can change the map from street view to satellite view. It doesn't crash now, but doesn't show satellite map, just street view. Although the satellite view does show in the flying control part of the app. Strange. Hope they fix it soon
2017-10-26
Adam9997
Flight distance : 2619426 ft
Jyunte Posted at 2017-10-26 15:01
Same issue on iPad mini 4. As soon as I switch to satellite view app crashes
2017-10-26
DJI Thor
Flight distance : 13602 ft
For the trace of the flight, the preview of the route is weak, please play the whole record and see if it will show the route, it is in yellow.
For the crash of changing the map view of flight record, please try to reinstall the app to see if it helps, don't forget to sync your flight record before you do it.
2017-10-26
Albatros24
@DJI Thor
Thank you, but already done !
2017-10-26
Jyunte
DJI Thor Posted at 2017-10-26 20:17
I had to reinstall the app anyway, because it would crash on startup. This bug occurs on a fresh install, so, reinstalling the app does not fix the problem.
2017-10-26
Locoman
Done that, still doesn't work
2017-10-27
CA Mavic Pro
Flight distance : 639652 ft
Lebanon
Haven't updated yet, I think I will wait for a few days..
2017-10-27
Locoman
CA Mavic Pro Posted at 2017-10-27 02:15
Good idea. I tried to see if I could revert back to 4.1.12, but no joy. at least I didn't up date the app on my iPhone so it works like it is suppose to.
2017-10-27
ro_flyer
Brazil
Done doesn't work... Why  don't you see for yourself,  @DJI Thor ??? I think this procedure its the FIRST thing everyone tries before showing up here...
2017-10-27
JRos
Flight distance : 677362 ft
Singapore
Same problem in iPhone 6s and iPad Pro 10'5 with iOs 11. App crashes when switches the map sattelite mode or Hybrid mode.
2017-10-27
Jenee 2
Flight distance : 7852129 ft
The route is there but it is very feint and only shows in light yellow after played. I think this does need to be fixed.
I agree with all others that reinstalling does not fix the app crashes when changing the map.
It is not a major problem, but it is always nice to know what causes an app crash in case in happens somewhere else in the app when not expected.
2017-10-27
Locoman
just updated, GO4 to 4.1.15 but haven't tried to connect or fly. middle of the night here. Will do it in the morning.
There was a problem with viewing the flight log files in satellite view and GO4 app crashing with ver 4.1.14 that appears to be fixed with ver 4.1.15. I had talked to DJI support yesterday and informed them of the issue with ver 4.1.14 and he was going to talk to their developer about the problem. Looks like he did.
Will post tomorrow how the app works with flying, weather permitting. It Snowed here yesterday. First storm of the year in Western Wisconsin, so flying may not be in my future.
2017-10-28
Albatros24
Thanks to the developers of DJI, the bug of the flight recordings is corrected!
Good flights to all!
2017-10-28
Locoman
just got done flying with 4.1.15. did a 5 minute video, no lagging or any other problem. played smooth as glass. Also took some photos and they all turned out good. would post some if I knew how to do it.
2017-10-28
Aardvark
Flight distance : 384432 ft
ro_flyer Posted at 2017-10-26 12:02
And V4.1.15 has landed, looks like it's sorted a few things.
2017-10-28
Jyunte
Aardvark Posted at 2017-10-28 10:25
I agree... 4.1.15 gave me no problems this morning on three batteries.
Latest firmware on the Mavic Pro, iPad Pro 10.5".
2017-10-28
ro_flyer
Brazil
Seems all good now...  no video lag, and flight records working as should be... tks DJI... but I'll be more careful when updating...
2017-10-29
DJI Thor
Jyunte Posted at 2017-10-26 22:30
Hi, iOS 4.1.15 was released. Please update to the latest version and see if it helps now.
2017-10-30
DJI Thor
Jenee 2 Posted at 2017-10-27 22:31
Thank you for your advice. As far as I know, the current way to display the route is decided after consideration, I personally think it is quite reasonable. But will also forward this idea to the engineers to know. Maybe they will also take it into consideration.
2017-10-30
CA Mavic Pro
Lebanon
ro_flyer Posted at 2017-10-29 16:09
Updating it now.. thanks for the info
2017-10-30
DJI Thor
ro_flyer Posted at 2017-10-27 16:34
I tried myself, and forwarded the case to the engineers. Things get fixed now. Thank you for your feedback.
2017-10-30
Jyunte
DJI Thor Posted at 2017-10-30 01:17
Already did... See post #28, above!
See this post for an annoying problem with 4.1.15 and switching to Sport Mode.
2017-10-30
ro_flyer
Brazil
DJI Thor Posted at 2017-10-30 03:00
Seems to be all good in 4.1.15 (didn't fly in Sport mode to see if the persistant warning is present) Please don't break anything else if you guys are going to fix the Sport Mode warning...
2017-10-30
Jenee 2
DJI Thor Posted at 2017-10-30 01:22
Thanks Thor but the gods in the technical section have fixed it in v 4.1.15 and all is good again.
2017-10-30
DJI Thor
Jyunte Posted at 2017-10-30 10:11
Hi, our engineers are aware of this situation, here's what they reply: we will optimize the options when switching to Sport mode  ASAP. Please follow the update for DJI GO 4 App.
2017-10-31
DJI Thor
ro_flyer Posted at 2017-10-30 13:56
No worries, our engineers will take good care of it.
2017-10-31
DJI Thor
Jenee 2 Posted at 2017-10-30 20:41
Thank you for your feedback. Happy flying.
2017-10-31
Albatros24
Hello everyone.
New update for iOS (version 4.1.16) and return of the problem of the trace of the mavic in map mode !
The trace is almost invisible, like in version 4.1.14 !
2017-11-4
