dji mavic pro battery error
1204 5 2017-10-29
fansacc9126e
Flight distance : 587339 ft
Israel
hello - I have dji mavic pro combo and one of the  battery  after 10 charging - start make A problem .  -
Is there a possibility to fix it?   or throw away   - thanks dji 100$ go
error
error
2017-10-29
Jffoto
Flight distance : 709 ft
Sweden
Tried the solution like it says?
2017-10-29
fansacc9126e
Israel
yes i dischrging it to 8%   after  charge it agian - but same  after its stop chrage and battery  show one light green
2017-10-29
Bill in Ohio
Contact DJI about getting a replacement battery.  If the last statement that battery cell is broken, they will be able to verify and sounds as if it is in warranty?
2017-10-29
DJI Thor
Flight distance : 13602 ft
Had you tried to restart the battery for times, or checked the battery status to see the differences of each cell? If the problem persists, I suggest sending the battery in if it is under warranty period (6 months and charge cycle less than 200 times). You can contact support@dji.com for a further help.
2017-10-29
fansacc9126e
Israel
I am not sure the battery  under warranty
2017-10-30
