Osmo+ and Pro/Raw Z-axis?
862 2 2017-11-1
Felipe Olvera
Flight distance : 94849 ft
Hello all! i was curious to know if anyone had the Osmo+ as well as the Pro/Raw Z-axis to test if it will work? My plan is to purchase a Osmo+ and a Zenmuse m1 to use interchangeably. Osmo+ for planned shots and M1 for more quick shots. However I would also like to purchase a z-axis to work with both. My options are (1) buy regular z-axis and add separate spring to help support zenmuse m1 + phone, as well as zenmuse x3 (osmo+). Or (Option 2) buy Pro/Raw z-axis if it works with both. Can anyone provide video or photographic evidence (even personal testimonial that you tested it) of the osmo+ working or not working with the Osmo Pro/Raw Z-axis? I understand the DJI website says it is not officially compatible, but it also says that its not compatible with the zenmuse m1, but works. I have heard mixed responses from DJI reps, but want to see it to believe it.
2017-11-1
Felipe Olvera
bummppppp
2017-11-2
Osmo Z-Axis is only compatible with Osmo, Osmo+.
Osmo Pro Z-Axis is only compatible with Osmo Pro, Osmo Raw.
I know this is not what you want, why don't you go to the retail store which is nearest to you to have a test if you are available? It may be more efficient.
Here is the link to find retail stores: http://www.dji.com/where-to-buy?site=brandsite&from=footer
2017-11-2
