Poor Distance with P4P PLEASE HELP
779 9 2017-11-4
J-Man
Flight distance : 61381 ft
I have a P4P bought in July 2017 from Amazon and using a iPad mini4 with 128gb WiFi+Cell. I have tried and tried to get better distance with this unit but the furthest I have been able to go is 3400ft DISTANCE (.67 of a mile) pretty poor!
I’m in a somewhat populated area where I’m standing and where I fly is over wooded terrain and subdivision. I have tried both channels on Auto and the best came from the 5.8 band (3400ft) at an Alt of 275-350ft atp.
I even tried keeping iPad hot-spotted to my cell phone, I have up to date dji go 4 etc... I’m just at a loss...???
I have seen people claiming they get 3-4 miles... I can’t even get 1 mile.
Once I get to the above stated range, screen says lost connection or lost signal and the P4P enters RTH mode.
Do I have a bad unit???
Any help is greatly needed,
Thank you
2017-11-4
PaulSouthport
Flight distance : 1448799 ft
Make sure your antennas are oriented correctly, pointing straight up with the flats facing the phantom, clear line of sight.
Put your phone and go device in airplane mode
2017-11-4
fansf0a7b92a
Flight distance : 202254 ft
Hello...If you live in a well populated area it could be interference or if you lose line of sight you'll lose signal.
2017-11-4
J-Man
Thank you, so I read about putting in airplane mode... I went to do that but I noticed it turned off internet etc... does that not matter?
2017-11-4
ALABAMA
Flight distance : 10442687 ft
You don't need an internet connection to fly.
2017-11-4
J-Man
Okay, that I was not clear on. I knew you could fly without internet, but thought it helped if you did. So Alabama, you are saying internet is not used at all for flying then right.? Probably only useful for filming LIVE then?
Thank you
2017-11-4
Labroides
Flight distance : 9991457 ft
J-Man Posted at 2017-11-4 11:18
Thank you
There is no need at all for internet data while flying.
Try a different location if you want distance.
Urban areas are always going to give much lower range because of interference.
2017-11-4
Edward J Smith
Flight distance : 1852408 ft
You might try extending your height too the max of 400 feet.
2017-11-4
Geebax
'I’m in a somewhat populated area where I’m standing and where I fly is over wooded terrain and subdivision. '
Range depends mostly on the ability of the aircraft and RC unit to receive radio data, and the greatest enemy to model RC aircraft is WiFi, and any populated areas these days have masses of WiFi hot-spots. It does not matter if your aircraft is out over wooded terrain if your RC unit is back in the suburbs. You're not going to get anywhere near the advertised range until you get away from population and out in the countryside.
2017-11-4
hdlou94
Flight distance : 753163 ft
good luck, i have same issues and just get the run around
2017-11-4
