DJI Assistant Firmware Update using WiFi - Switch Off Mavic Radios?
1914 7 2017-11-7
nosaari
Flight distance : 124747 ft
Japan
This seems so obvious to me I feel stupid to even ask: Why are the radios of the Mavic enabled during a firmware update?Everytime I try to update my Mavic using my Macbook and the Assistant software it is a hit and miss. Downloading regularily fails and is very slow as the powerful radios of the Mavic kill my WiFi connection. Of course no way to preload the firmware or at least resume, always restarts at 0% ... And with the current Assistant version the Mavic needs to be connected and cannot even be switched off during the download, sitting next to the computer like a happy WiFi jammer.
And finally the update does not even fix long known issues like the broken .RAW format. Very frustrating experience.
Guess for the next firmware upgrade I will need to buy a very long USB cable and some tinfoil...
2017-11-7
DJI Elektra
Did you update your drone successfully? Please ensure that your PC have a solid Internet or change another computer and see if it works.This problem will be forwarded to our engineers for check. Thanks for your feedback.
2017-11-9
MDSH
Flight distance : 334869 ft
I always switch my WiFi to 5G when I'm updating my Mavic/RC firmware. It seems that the Mavic is siting there transmitting and trampling over the 2.4G WiFi but 5G WiFi seems just fine.
2017-11-11
Eagle_Eye
Flight distance : 4137720 ft
Is there a way to download the FW and install it offline.....I think this will solve most of the frustrations of upgrading.
Any DJI Mods.......can anyone comment on this?
2017-11-11
nosaari
Japan
MDSH Posted at 2017-11-11 04:29
If you have the hardware thats a good workaround
2017-11-15
nosaari
Japan
Eagle_Eye Posted at 2017-11-11 04:34
A few assistant versions ago you could switch off the mavic during the download and switch it on after it has fully downloaded the update. Unfortunately now this breaks the upgrade process and restarts it at 0%.
2017-11-15
nosaari
Japan
DJI Elektra Posted at 2017-11-9 01:49
Did you update your drone successfully? Please ensure that your PC have a solid wifi or change another computer and see if it works.This problem will be forwarded to our engineers for check. Thanks for your feedback.
It updated after many tries and after I put the computer and the mavic as far apart as possible. The computer was sitting right next to the router, it was very obvious that the mavic was drowning the WiFi signals. After I switched it of my WiFi came back immediately.
2017-11-15
DJI Elektra
nosaari Posted at 2017-11-15 21:14
Thanks for your update. This situation was reflected. Hope it can be solved in the future.
2017-11-16
