Update the Mavic Pro to the NEW FIRMWARE and it crashed
2146 12 2017-11-28
fans62b3fb6e
Peru
Today updated to Mavic Pro to NEW FIRMWARE 01.04.0100, the most recent, finished the download and installation, to test, in the place where I always fly, suddenly, the drone went into uncontrol, crashed, falling spectacularly to the ground, and the gimbal was broken, leaving it unusable, also hit the camera causing serious damage. Undoubtedly, the failure was caused by the update that was made an hour before the accident. The cell phone I always use is an Iphone 6 plus. I see 2 messages: Engine of the overloaded aircraft Check if cardan is removed. Gimbal restarting. Verify that the gimbal turns smoothly if the restart fails again. See that I buy it in OLX, I no longer have contact with the person who sells me. What should I do, where to claim, direct to DJI?
2017-11-28
DJI Thor
Flight distance : 13602 ft
Sorry for the crash, that must be frustrating. I highly recommend you sync the flight records and export the flight log, then contact the support to open a case, we'll submit a data analysis to find out the cause if the drone in under warranty period.
Also, please send the drone back and we will help to take care of it.
http://www.dji.com/support
2017-11-28
Yao
Flight distance : 250318 ft
New Zealand
Same issue as fans62b3fb6e. Updated firmware a couple of days ago and was alright until today. First flight of the day and it crashed spectacularly within a couple of seconds after it took off.
2017-11-29
Woe
Flight distance : 4129268 ft
This makes me so nervous as today will be my first flight since update. I hope everything works out.
2017-11-29
DroneFlying
Flight distance : 10774613 ft
If you retrieve and provide a link to the DAT file from the flight I'll take a look and may be able to provide some insight. The instructions for retrieving the DAT file are here and once you've retrieved it you'll need to upload it to DropBox (or a similar service) and provide a link to it here. The correct file will have a date and time that correspond to when the flight occurred and will be at least tens of megabytes in size.
2017-11-29
DroneFlying
Yao Posted at 2017-11-29 02:29
If you'd like to have someone outside of DJI look into this (or get a response more quickly) see my above post to the OP regarding the DAT file.
2017-11-29
Jumbo333
Flight distance : 797930 ft
DroneFlying Posted at 2017-11-29 06:57
Flight Data .DAT are not reachable since firmware .1000 , isn't it ?
2017-11-29
DroneFlying
Jumbo333 Posted at 2017-11-29 08:59
As far as I know it's still possible to retrieve the DAT files from the latest firmware releases.
2017-11-29
Jumbo333
DroneFlying Posted at 2017-11-29 09:37
What is the procedure ? Last version of DJI Assistant ?
2017-11-30
DroneFlying
Jumbo333 Posted at 2017-11-30 00:53
This is the same link that I provided above: Retrieving a V3 .DAT File
2017-11-30
BudWalker
Flight distance : 5966247 ft
Install and use  DJI Assistant 2 Version 1.1.6 and then look at this explanation
http://www.datfile.net/DatCon/retrieveV3Dat.html#CompressedFile
There are two options; using the Flight Record tab, or using the Data Upload tab. You want to use the Data Upload tab.
2017-11-30
Jumbo333
Ok, so 1.1.6 version is necessary !
Thanks !
2017-11-30
Matthew Chirico
Flight distance : 769160 ft
you see a post that says the update is good and then you see one like this...DO I UPDATE OR NO ughhh!
2017-11-30
