[size=14.666666984558105px]Here is a video I created that explains how you can charge your Mavic in the wild without a need for an electrical grid using powerbanks. You can the items you need in the video description. This system will allow you to charge yourMavicc Pro battery up to 7 times, under 50 minutes and it will cost you around $250. You can also top up your battery banks using a solar panel for longer trips.
