Can't Calibrate Mavic Sensors in DJI Assistant 2
19582 19 2018-1-2
Redsectora
Flight distance : 48287 ft
Hello
My dilema is my Mavic Pro connects to the DJI Assistant 2 no problem but when i choose Calibrate all i get is please reboot aircraft which i have done many many times and problem still happens.
Please can anyone help me as im running the latest DJI firmware on a current HP laptop (x64) which is running windows 10.I have checked in Device Manager and i'm on the current driver.
Any ideas?
Regards
Andy
2018-1-2
theothernt
Flight distance : 436171 ft
You can calibrate the IMU and Compass using the app on your phone/tablet...
2018-1-2
A CW
Flight distance : 13926112 ft
To calibrate the VISION POSITIONING SYSTEM SENSORS in Assistant 2 (which I believe is your actual question) it is important that you turn on the drone first then connect to the computer. Don't connect then turn on. Also, reduce the display size of the screen in your lap top/pc settings - I found 720 works all the time for this calibration.
2018-1-2
DJI Thor
Flight distance : 13602 ft
Andy, please try to restart the computer and the drone and connect the DJI Assistant 2 again, also, you can try to change another connecting cable. See if it helps.
2018-1-2
fans9fa373e8
Flight distance : 207500 ft
Sweden
A CW Posted at 2018-1-2 10:43
Hi!
I have the exact same problem, but nothing helps, i tried all you said...
Any other ideas?
2018-4-21
A CW
fans9fa373e8 Posted at 2018-4-21 12:12
Hi!
Any other ideas?
Try another PC/laptop and ensure you are on the latest version of Assistant 2 - you can also try uninstalling and reinstalling the Assistant 2
2018-4-22
Rovik87
Sweden
A CW Posted at 2018-4-22 00:13
I found a video which helped me: I restarted my computer in an advanced mode by holding down shift-key while pressing restart computer, chose adcanced options and then alternative #7 (....without signature blabla..). I also changed battery, then everything worked =)
2018-4-22
A CW
Rovik87 Posted at 2018-4-22 22:48
Thats a first but glad it worked out for you.
2018-4-22
KangaAir
Flight distance : 590974 ft
As of today I also have the message "recommending" recalibration of the sensors on my Mavic Air. I have a Macbook Air & iMac 24". DJI Assistant fails to deliver a screen pattern at any resolution on neither machines. Conclusion: DJI Assistant is an absolute waste of time on the Mavic Air, even with the latest update you can collect flight logs, or calibrate sensors. It is only good for a firmware update. Even DJI Assistant is not needed. Suggest DJI change the Assistant app developer quickly, and to a rapid re-design. They seem to have got it all wrong for months now. Most importantly, I am not at all worried about the sensors. They appear to work totally normal with the re-calibration recommendation being prompted. If you are worried do a front-rear-ground sensor check at launch, simple check. Sensors on mine bird are working fine. My guess is a firmware update will eventually remove this silly message. If it a genuine sensor problem DJI better get their act together quickly or there will a lot of unhappy owners Mavic Air out there with this annoying message. I recently flew in Halong Bay Vietnam from a steel boat, the drone and sensors were perfect even with the sensor alert activate. There are occasions where you may have to land without sensors anyway, good pilots should not totally rely on sensors to get them out of trouble in a tight space.
2018-6-4
fansc33daac8
KangaAir Posted at 6-4 01:42
I was having the same issue and nobody at DJI was able to help me. However, try setting your screen resolution to the lowest setting - in my case it was 1280X720. That did the trick.
2018-11-5
TC KABREW
Austria
calibrate the compass and IMU on you phone
2019-1-2
mur4d
Hi i am on mac OSX catalina using assistance 2 for mavic for Mavic 2 pro. calibbration goes well untill uploading. nothing happens. Any help? i am on macbook pro 15 2017
2019-11-1
Barwon Drone Photography
Flight distance : 832310 ft
mur4d Posted at 2019-11-1 04:20
I have the same problem
tried everything
different cables  tried mac  desk top then my mac book pro then tried my sons  pc
reinstalled DJI assistant on both mac and the pc
Does everything up until the last part where it says calibration and just stalls
2021-3-28
Barwon Drone Photography Posted at 3-28 02:42
tried everything
any solution ???
2021-3-28
djiuser_hgdOl5D37SHV
Sweden
Why is there no one from DJI staff stepping in to this forum and  olving issue?
2021-3-28
robotmonster
I was also having trouble with my sensors not activating during the calibration process using DJ Assistant.  What fixed the issue for me was disconnecting my external monitor from my Mac laptop.  I then restarted DJ Assistant and it worked fine.  I hope this helps.
2021-4-16
djiuser_TMurygAwibWq
Sweden
tried everything
I'm having exact same problem.
Tried reinstalling software, turning everything off and on, updating firmware, downgrading firmware, reinstalling the app, changing batteries, cables... everything.
Did you manage to fix your issue?
2021-10-7
djiuser_1PI6UoD5T9Ve
djiuser_TMurygAwibWq Posted at 2021-10-7 09:07
Hi, did anyone ever find a solution? I have been having the same issue for a year now. DJI is useless.
2022-6-17
djiuser_E4Q9uRZyxAiI
Nigeria
Having same issue with my mavic pro 2
2023-3-28
ro_walker
Brazil
2023-4-6
