akebla222
Flight distance : 26654 ft
Sweden
I have an issue with my spark as per below which I cannot figure out the reason for (nor Google the solution for). This is such a problem that I cannot use sports mode at all and I've almost lost / crashed the drone several times. I've also finally had a crash which broke one of the arms as a result of the problem. :/
Compass calibrated (same issue on several places with new calibrations)
GPS coverage (16-18 satelites I believe)
No wind
Height: 4-5m (15ft)
Phone connected to controlled via Wifi and phone in Airplane mode (no bluetooth).
All updates on Spark / remote done
(I believe I've seen a similat tendency without sports mode, but I'm not sure)
I engage sports mode and and I go straight forward between 20-30-40 meters (60-120ft) or more and then i let go of the forward command (soft or hard) and the drone slows down for the first second, then drifts right a lot! Always right and always a lot (a lot more of what I expect / see on youtube). I've tried having the drone in the air for up to 10 min before at different altitudes / modes / positions / speeds
Her's a drawing of the issue.
Anyone have any idea what the issue can be / how I can fix it? Or is it simply what to expect?
DJI spark drift on stop
