DJI Go Flight Records Sync
3234 6 2018-1-17
rmd610
Flight distance : 85200 ft
When I "Sync My Flight Records" from the DJI Go App, where do I find the synced records?
Thanks all...
2018-1-17
DJI Elektra
Sir, if you sync the flight records successfully, you can log in your accound in other device and snyc the flight record there. Here is the way of syncing them.
2018-1-17
rmd610
DJI Elektra Posted at 2018-1-17 20:10
https://www.youtube.com/watch?v=brKQZ-gTBXg
I have synced the records, my question is, where do I review the synced records??
2018-1-22
dj_dread
Flight distance : 648399 ft
Romania
go into the DJI Go 4 app. tap onto the upper righ hand corner where you have the 3 lines. tap onto Flight Record. at the bottom of the screen you have the "flight list". drag the "window" up and you will have the list of all your flight records.
hope this helps.
2018-1-22
rmd610
dj_dread Posted at 2018-1-22 12:42
hope this helps.[view_image]
I don't know how to say this any more simple --- how do I view Flight Data on a computer or other device other than through DJI GO?  This is the question I asked in the first place.  Thank you!!
2018-1-23
dj_dread
Romania
ok. sorry, i did not understood you question.
connect your Spark to your computer and use DJI Assistant. Retrieve the logs and upload them here: http://www.phantomhelp.com/LogViewer/Upload/
that would give you the flight logs.
2018-1-23
rmd610
Ok, I'll try that.  Thank you.
2018-1-23
