ATTI and speed error
1226 9 2018-1-21
KevinP3S
Flight distance : 14058 ft
South Africa
Hi All
When looking @ my logs of my flight I notice that it goes into ATTI mode with a speed error ... what would cause that ?   It did a "flyaway" to towards some trees so I did a "forced landing " lucky it was not to high . Also on Auto Takeoff I see that I get a negative value for Altitude
2018-1-21
KevinP3S
South Africa
I got feed back from a different forum...basically saying that the GPS and Compass didnt sync with the speed so it swapped to atti mode ...but I am not sure which was at fault...or how to prevent or fix the issue from happening again
2018-1-21
Peterx
Flight distance : 1499708 ft
In what flight mode you got a "flyaway"? Was it in P,A or F mode. If it was in F-mode,then what F-mode was it,F-Follow me?
2018-1-21
Betamace
Flight distance : 2133 ft
That negative altitude during take off is normal since the prop wash is increasing the atmospheric pressure between the aircraft and the ground surface. Zero altitude is  set according to static barometric pressure at the aircraft's position before the rotors spin up.
2018-1-21
djiuser_JICNR6o
Flight distance : 32323 ft
This just happened to me and it was a total loss. It fell from 390 feet.
2018-1-21
djiuser_JICNR6o
http://app.airdata.com/main?share=nvDmPW
2018-1-21
KevinP3S
South Africa
I was in P mode
http://www.phantomhelp.com/LogViewer/C6WO9Z4A8HPE8OO0TEDS/
At 6:41.3, when the error messages start  (thanks Meta4)
2018-1-21
DJI Susan
Hi Kevin, just to verify, do you use the DJI GO when the message pops up, right? Could you post a screenshot of the error message and sync the flight records for better assistance? Please kindly leave your DJI Account as well, we'd like to look into it.
2018-1-22
KevinP3S
South Africa
thanks... sorry I do not have screen shots ... all my flights are synced ...What account details do u need ??
2018-1-22
KevinP3S
South Africa
thanks for the feedback DJI......not
2018-1-30
