H3-3D freaking out
2680 18 2015-4-25
thaug29
DJI I need help with this.  I have an H3-3D. It runs fine for about 4 minutes; then it pitches all the way up (skyward) and to the right and then starts shaking like it wants to go home but can not.
It won't stop until I unplug the battery. Then it will run fine again for about 4 minutes.
Please HELP.
2015-4-25
pggg
Switzerland
I have the same issue - usually happens after 6minutes, usually in forward flight and starts nearly always when tilting down.
But it doesn't happen in every flight. Usually every 6 to 10 flights,
Below a video - and like you usually I have to switch off the Phantom. On rare occasions it restabilizes.
Tried advanced IMU calibration, using 4 sets of different DJI propellers all new, doing a gimbal hard reset and uploading firmware again, using all possible dampers, using 4 different batteries calibrating compass prior each flight and the list goes on  but this behavior returns.
Also have this vertical jittering when gimbal is not in shaking mode:
This is on a Phantom 2 v2 never crashed, never tipped over with mini IOSD and anti interference board both mounted inside the Phantom.
I think the gimbal is toast -
DJI wants me to send the whole quad in. And as this is not happening every flight I doubt they will get it fixed and waiting time is 1 to 2 months at the best.
Will probably come out cheaper if I buy a gimbal and cross my fingers that that is the issue - unless someone here has some idea what could be the cause.
2015-4-30
thaug29
pggg Posted at 2015-5-1 06:05
I have the same issue - usually happens after 6minutes, usually in forward flight and starts nearly  ...
There seems to be an issue with this gimbal and DJI can't even supply an answer.  They are suppose to be the best and this is what we get, silence.
2015-5-1
jcolip1985
Guam
Mine went bonkers today after an upgrade. I calibrated it after the upgrade through the Phantom Assistant and it was really touchy. It would jerk and the gimbal wheel was very sensitive when moving it up or down. I ended up having to change a bunch of the numbers in the gimabl calibration portion. I finally zero'd in on what I think will be comfortable for me, we shall see. I am flying her tomorrow I'll post back to let you all know if I fixed it...if you are interested.
2015-5-4
pggg
Switzerland
Yes please post - I bought another H3-3d - I hope that will be the fix!
2015-5-4
DJI support 8
Dear customers,  suggest you send the gimbal back for test and repair,
You can find the nearest support center from you from the link below to get in-time help.
http://www.dji.com/support
2015-5-4
jcolip1985
Guam
pggg Posted at 2015-5-5 04:03
Alright, so I nervously (I had a slew of problems after RC/P2 and H33D upgrades) took to the air today to see if my H33D is still working. Good news, it still is working. Bad news is that the gimbal wheel is now overly sensitive after the upgrade.
When I try to tilt in either direction it will max out and then shoot the camera the opposite direction in a very jerky manner. Sometimes it will even cause the GoPro to nod up and down very quickly as if to nod yes.  I plugged it into the RC and P2 assistant and it does the same thing with the arrows in the program. This all occurred after the recommended upgrade from DJI.
After a few hours of calibration (yes hours) and sensitivity setting I managed to get it to where I think I will be comfortable. The wheel is still very touchy but it does move the camera with the occasional jerk. Overall it still holds a solid and steady picture. I just set it to the angle I want it at and don't touch it during flight. This currently doesn't bother me because I do not have FPV yet. I am sure it will be an annoyance once I have FPV.
2015-5-5
djgpss
Flight distance : 1127654 ft
Greece
Hi! I have the same problem on my f450!
Look the video from 0.23 and after!
I have last firmwares!
Does you solved?
2015-6-13
Dji support 8
djgpss@gmail.co Posted at 2015-6-13 22:02
Is your gimbal firmware updated to the latest?  If yes,  the IMU may has some problem. Did the gimbal crash before?
2015-6-15
djgpss
Greece
Hi... Yes i have latest firmwares and never crash my gimbal. Its a new!  I use gopro hero 3 black plus!
2015-6-15
islandflyer
Guam
jcolip1985@hotm Posted at 2015-5-5 16:03
Alright, so I nervously (I had a slew of problems after RC/P2 and H33D upgrades) took to the air to ...
Hey JColip! Looks like we are on the same side of the world...in the same little Pacific Island
If there is one word to describe the H3-3D it would be - 'inconsistent'. The 3D on my P2 performs pretty solidly 95% of the time (although there was that one time I upgraded the firmware and bricked it). The 3D that was on my F550 (using the H3-2D GCU) was also pretty solid. But my new H3-3D mounted on my Tarot 680 (with H3-3D GCU) is junk. I've already sent it back to my vendor and hopefully the new one is problem free. If not, then the problem might be the GCU.
Anyhow, we should have a DJI meet up and do some flying. Lots of guys on island with Phantoms, 450, 550....and now one with an Inspire 1.
2015-6-15
Dji support 8
djgpss@gmail.co Posted at 2015-6-15 21:02
Hi... Yes i have latest firmwares and never crash my gimbal. Its a new!  I use gopro hero 3 black pl ...
Hi, please add my working skype Candice-zhu( Shenzhen, China), I would give you a downgrade to calibrate the gimbal to see if this method can help you solve the problem.
2015-6-16
djgpss
Greece
Hi  Dji support 8 thank you for your interest but it is not very easy for me to contact you through skype because I do not speak english very well
and right now someone else is writing this message for me.
Is there another way maybe a video that I can watch or send me by e-mail a firmware for downgrade?
thank you!
2015-6-16
Dji support 8
djgpss@gmail.co Posted at 2015-6-17 07:09
Hi  Dji support 8 thank you for your interest but it is not very easy for me to contact you through  ...
The downgrade can only done by us after application, currently we don't have the video.
You English is good. I can understand. No worry.
2015-6-16
Cessna172
Can some of youse guys please post the outcome of these issues?
2015-7-29
djgpss
Greece
Hi again...
I tried everything ... reinstall firmwares, I put the last state versions firmwares, I balance the gimbal, put zenmuse anti interference board lest corrected the problem ... but still nothing !!!
All that remains is to get the hammer !!!
2015-8-11
paul
Switzerland
djgpss@gmail.co Posted at 2015-8-11 23:03
Hi again...
I tried everything ... reinstall firmwares, I put the last state versions firmwares, I  ...
Viewing your video it really is very similar to how mine goes crazy (see my posts under pgg).
Some downward pitch, gimbal starts vibtrating and then major shaking.
Like I posted above, I bought myself a new gimbal, and it works perfectly
In the meantime DJI Germany finally accepted to RMA the gimbal only. At first they wanted to have the whole combo with Phantom, remote etc.
After a couple of weeks they returned it with only one printed sheet but I can't make out whether   it has been  repaired it or not. As my newly bought gimbal  is working perfectly I can't be bothered anymore to test whether the RMAed one has been repaired.
2015-8-31
tom.breathnach
Flight distance : 144649 ft
Dji support 8 Posted at 2015-6-16 12:28
Hi, please add my working skype Candice-zhu( Shenzhen, China), I would give you a downgrade to cal ...
Hi, I would like this downgrade too, please see my post in the help section....
2015-9-27
tom.breathnach
I would like this too
2015-9-27
