Bella Gorden
China
If you have noticed vertical lines on your iPhone, you don't need to worry about this issue. You can use several ways to solve the issue and I would share some ways I know for fixing this issue.
1. Force Restart iPhone to Fix Red Line on Screen:
For iPhone 8 or Earlier: 1) Press the top (or side) button and hold it until the slider appears; 2) Simply drag this slider and turn the device off; 3) Now, you should press and hold the Top button (or the side button ) until the Apple logo appears.
For iPhone X: 1) Press Side Button and volume (+ or -) button and hold them; 2) Once the slider appears, drag it and turn the iPhone X; 3) Now, you should press and hold the Side Button once again to start your iPhone X.
2. Reset iPhone to Fix Red Line on Screen:
1) Go to “Settings” and tap the “General” option; 2) Then select the “Reset” option and tap “Erase All Content and Settings”; 3) If prompted, you should log into your Apple ID using the credentials; 4) Provide confirmation when prompted and wait patiently until the device gets erased.
3. Restore Your iPhone to Fix Red Line on Screen:
1) Start by opening iTunes on a computer and connect your iOS device to the computer (a Mac or a PC to do this) using the original cable; 2) If prompted, you should follow the onscreen steps by providing the passcode; 3) Select the iOS device as it appears on iTunes and you will find the summary panel and click on “Restore” option; 4) When prompted, you should confirm the restoration process; 5) Now, your device will be erased through iTunes and the latest iOS version will be installed and the device will function like a new one and configure the way you want.
4. Fix iPhone Red Lines on Screen with iOS Repair Software:
If the above methods still cannot solve your issue, you can use a tool for fixing this issue. Then you can make sure that you can fix the problem while keeping the data on your iPhone. With the help of the professional tool, you can fix your issue with ease.
