Flimsy Handle of Inspire 1 Case
1376 5 2015-4-30
krusher
Philippines
I experienced the flimsiness of the handle, actually its the one that is anchored on the case.  I grabbed the case, because I was in a hurry, the thing connecting the handle and the case just broke and I dropped the case.  Fortunately, the case was fine.  Hence, i tried some DIY solutions, and here it is
2015-4-30
lethbrp
I bought these from eBay
http://www.ebay.co.uk/itm/261788 ... =STRK%3AMEBIDX%3AIT
They work very well indeed. Much better than the original parts.
2015-4-30
fullyestablishe
lethbrp Posted at 2015-4-30 17:48
http://www.ebay.co.uk/itm/261788385875?_trksid=p2057872.m2749.l2649&ssPage ...
Following a recommendation here I bought the eBay set from this seller and it is now the strongest part of my case. The product was delivered in a couple of days and is superbly engineered, fits in seconds and was really reasonable priced. This guy!s feedback speaks for itself.
2015-4-30
PeteGould
I can vouch for the ebay set as well.  The seller is actually located in Colorado, so if you're in the USA you can access via the US ebay site:
http://www.ebay.com/itm/DJI-Insp ... l-Set-/261788403700
The above set is the handle hardware AND replacements for all the feet.  The feet on the DJI-supplied case are hollow and tend to break.  The accent parts supplied in the above package are solid.  We changed everything over - took about fifteen minutes and a Philips-head screwdriver.
2015-4-30
chrisfromalbany
What about the foam inserts inside case that falling apart everytime you put the inspire in and out of the case?
2015-4-30
PeteGould
chrisfromalbany Posted at 2015-5-1 08:27
What about the foam inserts inside case that falling apart everytime you put the inspire in and out  ...
I can't vouch for this product, but someone is making 3D-printed inserts for the motor cutouts on the case.
www.ebay.com/itm/Inserts-for-the ... serts-/251915979712
2015-5-2
