RobDownUnder
Flight distance : 103609 ft
Where there is a wide dynamic range of light such as sunset, you might like to try two exposures or even three from the same location. Using the wheel on the controller you can adjust each image. Get the sky right in one and the landscape right on a second image. Software is available to merge the images on top of each other, or simply cut a line at the horizon and join the images.
Also remember, you have a wide angle 12 megapixel image so the detail will be acceptable for 99% of the population, but maybe not magazine quality. That requires a much more sophisticated camera.
But unlike those with heavy cameras, you have the elevated shot, they don't. |
