PRO TIPS for not losing another MAVIC AIR gimbal clamp?
1511 20 2018-2-26
jamborini
Flight distance : 69682 ft
I lost mine (for my AIR) within a week (did the same with the Mavic Pro). It does make you wonder why they make them dark and diaphenous. I'd only be less suspicious if they made them camouflaged as grass.
Anyway, also incompetance in losing it.
So I've put some red tape on the top of it and Iwas going to drill a hole in the top of it and put some string through and try and attach it to the Mavic case. But it's a nice case. Has anyone tried this yet?
2018-2-26
Malakai_UK
Flight distance : 536115 ft
lol not taking the mickey but seriously!!!. Its an integral part to the aircraft, like a prop or the controller. Why not put it in the case, bag, zipped pocket, front trouser pocket, dashboard of the car or someplace safe? No offence but i get a pang of frustration in me when I hear people lost things like this lol. They are cheap enough anyway to replace. Where abouts in the UK are you?
2018-2-26
jamborini
I'm in London. It cost me 12 pounds to replace it.
I DID put it in a trouser pocket.* I swear to god. But I have no idea where it went.
*it's possible I might not have put it in a trouser pocket.
2018-2-26
Mars5150
Flight distance : 391493 ft
Pro Tip!  Hahaha
Try not forgetting your Head home before you go flying your Drone...
2018-2-26
Thudd
Flight distance : 1624787 ft
jamborini Posted at 2018-2-26 07:26
May I suggest after removal, attach one of these.
https://www.amazon.com/Marco-Roc ... =marco+polo+tracker
In keeping with the humorus atmosphere.
2018-2-26
jamborini
Thudd Posted at 2018-2-26 07:35
https://www.amazon.com/Marco-Rocket-Location-Recovery-System/dp/B01F4DOB5C/ref=sr_1_1?ie=UTF8&qid=1519659288&sr=8-1&keywords=marco+polo+tracker
Probs need 2 for good measure right?
But what if I lose that?
2018-2-26
Malakai_UK
Might work out if you get a small keyring loop. Drill two small holes to feed the keyring loop through and attach a small carabiner clip to the loop. This way when you take it off you can clip it to a belt loop.
2018-2-26
jamborini
Malakai_UK Posted at 2018-2-26 07:56
That's a great idea. I was planning on attaching it loosely to the inside of the case.
2018-2-26
Blizzard
Flight distance : 173734 ft
I did drill a small hole into it, and with a string, I attached those little banners "REMOVE BEFORE FLIGHT"
So, I don't forget it anymore to remove it, and its always easy to find back.
2018-2-26
MiniPalourde
Blizzard Posted at 2018-2-26 08:19
I use a check list instead. But I admire your dedication lol
2018-2-26
Datadogie
Flight distance : 27028 ft
Check the washing machine.
2018-2-26
Malakai_UK
If you don't fancy drilling holes (dust gets in) epoxy a ring to the bottom.
2018-2-26
StanfordWebbie
Flight distance : 178018 ft
I put a long red ribbon on mine, attached with sticky velcro on both the bubble and the ribbon.  Every now and then, I have to replace one of the velcro's, but I NEVER forget to remove the bubble before flying.  And, in your case, make it a loooooooooooong red ribbon,
2018-2-26
Sim-Y
Flight distance : 75502 ft
Not a tip but i bought one of these AIO , works perfectly & i never fly with the cover on anyway.
2018-2-26
jamborini
StanfordWebbie Posted at 2018-2-26 10:53
NOW THAT is a GOOD IDEA!
2018-2-26
fans1215d7b7
Flight distance : 168999 ft
What i do.... is put the clamp in the case the moment i take the MA out of the case.
2018-2-26
AG0N-Gary
Flight distance : 700846 ft
When I pull the Mavic out of the case, the cover(s) and gimbal clamp are removed at the same time and stay in the case.
2018-2-26
Mullheliflier
Flight distance : 12305135 ft
Same here. Main reason is so that I do not power up with it attached and the second so that I do not misplace it.
2018-2-26
jamborini
Exactly. This is for my Mavic Air but same thing when I had the Mavic Pro
Now what I do is I have a system. I open the case, I take out the Air, I remove the gimbal clamp and put it somewhere I definitely won't be able to find it. Then I zip up the case and begin preparing for take off.
2018-2-26
ZzZoe
Flight distance : 170627 ft
do you think that a red or other colors clamp fit for a black or white drone?
2018-2-26
Tom_A
Flight distance : 899951 ft
In the washing machine? Same place my garage remote ended up one time. That thing kept on working through the whole wash and dry cycles.
2018-2-26
