Dji spark, problems after changing to 2.4ghz. (Return to home alt..)
1193 7 2018-2-27
Kimjorgen
Flight distance : 4911 ft
Norway
After reading about 2.4ghz vs 5.8ghz, i decided to give it a go.So i changed to 2.4ghz, first of all i lost wifi (android), solved that issue with otg-cable.
I get connected, ready to fly, all is good. Except a couple of things.
I can't enable anything in the "visual navigation settings", obstacle avoidance etc...
Can't enable rth at current altitude.
Can't adjust low battery warning.
No signal under the image transmission setting.
Can't enable gesture controll.
All of this occurred when i changed to 2.4ghz and otg-cable.
Any ideas why??
2018-2-27
dj_dread
Flight distance : 648399 ft
Romania
probably because OTG is not supported for Spark.
but i'll let DJI and the other forum members weigh in..
2018-2-27
Kimjorgen
Norway
Solved..
Installed dji go 4 v. 4.1.15.
Works fine with 2.4ghz and otg now
2018-2-27
dj_dread
Romania
thanks for letting us know!
2018-2-27
Wachtberger
Flight distance : 261509 ft
Kimjorgen Posted at 2018-2-27 12:52
Solved..
Yes, for the time being this is the only solution to have OTG working on Android.
2018-2-27
Spark877
Malaysia
I had almost same experience but using IOS
Now back using 5.8Ghz
2018-2-27
Strobing_NYC
Flight distance : 3866470 ft
Can I throw something out there? If you all would search the forum first you would save yourself the time of posting a redundant thread that had been beat more then my X wife (joke) OTG doesn't work with Android unless using DJI GO 4.1.15 or lower. Mods please sticky that!
2018-2-27
davidmartingraf
Flight distance : 108805200 ft
I haven't used the OTG cable with the Spark, but I have a Mavic Pro that uses the built-in OTG cable to side of the Remote. Honestly, the connection on Ocusync disconnected once I got far in range, further than I usually get with the Spark at similar spots, and the connection was spotty and so I don't think going from WiFi to OTG really will improve the transmission if the Ocusync from Remote to Phone can't handle the range distance itself?
2018-2-27
