Chinese Mavic Air 12V charger!
564 1 2018-3-19
veletron
Full report tonight. 12quid with dual outputs. From fleabay. Took 3 weeks.
2018-3-19
LoSBoL
Flight distance : 666483 ft
Sweet!  Can I ask you to test something for me?
I would like to know if you charge just one battery, how fast does it charge? Or better said, does it charge 1 battery faster then when it charges 2 batteries?
The reason I ask is because of the following, I need a SLOW charger which I can use on my motorbike without it pulling to much current.
I've seen these chargers with either one or two outlets. The charger with one outlet is supposed to have an faster charge rate, while the two outlet charger devides the charging output (at least, that's what the discriptions say).
Basically I want to know if this charger still charges at a slow rate with just one battery attached.
2018-3-19
