DJI Goggles - Worth Buying?
2146005503 2146005503 2018-3-21
davidmartingraf
Flight distance : 108805200 ft
Hi All,
I have DJI's Mavic Pro and Spark but was wondering how the DJI Goggles fare - is it worth a buy? Is the transmission way more reliable and immersive than just using regular FPV of a smartphone?
Any candid feedback from folks who already have the Goggles is greatly appreciated.
Thank you.
Single SelectVote, Total 73 people participate in voting View Poll participants
Voting has ended
36.99% (27)
45.21% (33)
17.81% (13)
Your user group with no voting privileges
2018-3-21
Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
yes - depends on your style of flying - but mostly i would say yes for sure.
2018-3-21
davidmartingraf
Bekaru MP UAV Posted at 2018-3-21 15:37
That is exactly the kind of feedback I'm looking for - thank you.
2018-3-21
DroneDriver
Flight distance : 1164226 ft
I can fly in a way with my goggles that I would NEVER attempt to do without them. Way more confidence, that no phone or tablet screen came close to providing.  I fly under bridges and right up mountain sides with no fear. I really like to fly my Phantom 3 4k but don't because I can ride along with the Mavic. I dumped all the whistles and pano BS and rolled way back to a stable fw. Real happy, now.
2018-3-21
M2Wair
Flight distance : 1192231 ft
Use the goggles with the inspires and Air so far and have proven to be invaluable, so yes well worth buying.
2018-3-21
DroneDriver
DroneDriver Posted at 2018-3-21 16:58
Guess I should have added that it is an experience like I have never had before, yea, that good.
And I get to do it every day.
Sport mode 2 feet off the ground balls to the wall. You better be leaning against something!
2018-3-21
Jay W
Flight distance : 259462 ft
Malaysia
This is going to add another item to my "to buy" list for the MP.
2018-3-21
BranDrone007
Flight distance : 1179039 ft
You will NOT regret getting the goggles, I can almost guarantee it! Everyone is different and have different tastes for sure.. I also have a Mavic Pro and Spark and the quality of video and signal transmission from the goggles are so good! To be honest, the video quality when using the Mavic is best, you’ll get the full HD experience... I absolutely love them!! I hope that helps... it’s a no brainer, I’m telling you!!
2018-3-21
Aardvark
Flight distance : 384432 ft
I have the goggles, which work well and were primarily developed with the Mavic Pro in mind (Connection to spark would be USB to controller, and limitations apply if aircraft is not initialised with a device running a 'logged on' DJI Go 4 App').
From a practical point of view unless your eyesight is perfect you will need glasses (I have prescription reading glasses, set for reading distance about 9.5 inches if I remember correctly). Many have also had success with 'focus fixing' lenses that can clip into unit. It is a very immersive view, and I find them comfortable enough to wear even with my glasses.
You will also likely need a 'spotter', somebody to keep an eye on the sky for other aircraft & objects that might cause problems. I'm not sure what the FAA rules are, but imagine they would be similar to CAA here in UK.
One of the biggies is the Ocusync wireless feed to the goggles, which at close range gives you a 1080P FPV stream. Also you can give goggles to another person, fly Mavic Pro using your standard display and give them a birds-eye FPV flight :-)
With latest firmware you can also playback any .mov or .mp4 movies on an sd card inserted into goggles, or view your Panoramic photos using head movement.
If you can afford them then I would get them, but be prepared to spend a little time getting correct reading glasses or whatever to get focus good. When that works well then you will enjoy the experience.
There are one or two threads already that are worth reading both here and in the Phantom 'Goggles' section.
2018-3-21
davidmartingraf
Do the Goggles have a much different interface of the DJI GO 4 than the smart device version? I'm just saying because I have FPV goggles that you can slip in your smartphone and view the app in, I did this with the DJI GO 4 app and the image was good but I would be reluctant to fly under bridges using it, so I'm just asking if the Goggles have a different kind of interface that allows you to see the image more intimately? Thanks.
2018-3-21
davidmartingraf
BranDrone007 Posted at 2018-3-21 17:22
Thank you for the feedback. All the input I'm getting it's making me think long and hard about getting the Goggles. Thanks!
2018-3-21
Woe
Flight distance : 4129268 ft
Definitely get the goggles. I got my Re’s in December and been very happy.  Like DroneDriver said you fly with more confidence.
2018-3-21
davidmartingraf
Woe Posted at 2018-3-21 18:01
OK, thank you for the reply.
2018-3-21
davidmartingraf
Aardvark Posted at 2018-3-21 17:24
I will take a look at the two threads that are worth mentioning, thank you.
2018-3-21
davidmartingraf
Jay W Posted at 2018-3-21 17:14
I'm probably going to be in the same boat as you :-)
2018-3-21
DJI Diana
Flight distance : 2408 ft
Hi, there, as far as I am concerned, the Goggles is worth buying.
2018-3-21
Montfrooij
Flight distance : 2560453 ft
Not in the Netherlands.
We are not allowed to fly without LOS.
So you can share your view with somebody else, but not with yourself.
Now I know there are pilots that still do so, but that is another discussion
2018-3-21
Andrew_tw
Flight distance : 1157464 ft
M2Wair Posted at 2018-3-21 17:08
So DJI goggles works fine with Mavic Air?
Just like to confirm this... thanks
2018-3-21
Skymax.
If you mean the new RE Goggles I love them. but you won't want to use them all the time.
Have you're Tablet running too so you can quickly switch from one to the other, I like to swing the Goggs up and go to the tablet for Takeoffs and landings.
Great fun is using you're Tablet and giving the goggles to a friend so you can both fly in the same Drone, huge fun!
Then again a minority just hate goggles of any kind..
2018-3-22
M2Wair
Andrew_tw Posted at 2018-3-21 23:30
Yes, but whatever mobile device you use will not be operable. We use them mainly on the inspires, one person on the camera and a second to fly.
I would suggest using your goggles with a spotter if used with the air.
2018-3-22
DroneDriver
davidmartingraf Posted at 2018-3-21 17:47
The phone in the VR goggles is a joke, a toy, poor man's gaming tool.
If you like the Mavic, you cannot imagine how good this looks and adds depth to the experience like NOTHING else. Do yourself a favor and find a way to try them out.
Owning a Mavic and not having goggles would be like owning a pair of shoes and just wearing one of them, now that I know better.
They look stupid, feel stupid when you wear them, and take a while to learn how to use them. Just call me King stupid on the honor roll...
2018-3-22
Jeff Millard
Flight distance : 503635 ft
I have a P4P+ and Goggles. Flying with the Goggles on is the ultimate experience. It completely changes your perspective. Just make sure you learn the settings, and the use of the control pad before you fly.
Jeff
2018-3-22
CoreyB10
Flight distance : 1665023 ft
DJI Diana Posted at 2018-3-21 23:04
But why are they sooooooo big DJI Diana...??
2018-3-22
CoreyB10
Skymax. Posted at 2018-3-22 00:08
The RE editions can also be used with Race Quads but I wouldn't turn up with these as they so mahoosive compaired to a pair of FatShark goggles. Just why are they so big ?? Surely the wizards at DJI Bat Cave could have come up with a smaller pair...
2018-3-22
davidmartingraf
DroneDriver Posted at 2018-3-22 03:06
Excellent and I appreciate the perspective from phone in VR goggles compared to DJI Goggles. I'm getting great feedback from everyone and it's certainly helping. Thanks.
2018-3-22
FatherXmas
Flight distance : 4058619 ft
They're great for public relations too. Hand them to a bystander and let them see what the AC sees while you fly around in sport mode. Everyone I've done this with is extremely impressed.
2018-3-22
davidmartingraf
FatherXmas Posted at 2018-3-22 15:34
Good suggestion, thanks for the input.
2018-3-22
lannes
Flight distance : 4465 ft
davidmartingraf Posted at 2018-3-22 16:43
I'd also have a look at the Epson BT-300 glasses as a comparison
2018-3-30
QuadKid
Flight distance : 482349 ft
I have a pair of FatShark V3 Dominators (which I have had for years) that I use for my racequads (they have an HDMI MIni In port), I equipped my P3P with a HDMI module a couple of years ago to get FPV out of the P3P, that was one of my critical reasons I bought the Crystal Sky, because it also has an HDMI output and the CS works with all DJI Models, so now when I want to fly FPV with any of my drones I just use the CS. The FatSharks give me more versitility. I clicked maybe, they are a good accessory but there is a learning curve to flying FPV and some people have a hard time adjusting.
2018-3-30
davidmartingraf
lannes Posted at 2018-3-30 16:05
Yes - I have reviewed them. The Epson BT-300 glasses are more of a image painted onto your retina type technology, rather than the DJI Goggles as being more of an ambient lighted display that you're watching up close.
Both have their appeals and drawbacks.
I think the DJI Goggles are probably the better to use of the two, when flying a Mavic Pro or Spark. I'd just wish that the size and overall cumbersomeness of the DJI Goggles were more like your typical Fatshark FPV race goggles or something aka small and compactness.
Thank you.
2018-3-30
eried
Flight distance : 787621 ft
Norway
davidmartingraf Posted at 2018-3-30 20:39
I have a different option, got the googles last November and after few flights I prefer to use the phone to fly. I do not feel like ”flying" or any 3d effect with the goggles. Also, for watching movies or anything else I think my cheap Daydream is nicer.
2018-3-31
LoSBoL
Flight distance : 666483 ft
With those goggles on you can't see the cop car pulling over next to you to fine you for flying beyond visual line of sight.
So I voted not worth it, since the laws over here prohibit you from flying with the goggles on.
2018-3-31
Aardvark
LoSBoL Posted at 2018-3-31 03:46
Can you not use somebody as a spotter, as is allowed in U.K ?
2018-3-31
Aardvark
p.s the Goggles U.K price in DJI store has been cut from £499 to £349.
2018-3-31
LoSBoL
Aardvark Posted at 2018-3-31 06:45
That's a very good question, and must admit, I really wouldn't know.
2018-3-31
Aardvark
LoSBoL Posted at 2018-3-31 08:10
This is an extract relating to UK models flying FPV:-
1) The person in charge is the person piloting the SUA.
2) The person in charge is accompanied by a competent observer who maintains direct unaided visual contact with the SUA sufficient to monitor its flight path in relation to other aircraft, persons, vehicles, vessels and structures for the purpose of avoiding collisions and advises the person in charge accordingly.
2018-3-31
davidmartingraf
eried Posted at 2018-3-31 03:39
Glad to hear your review and I appreciate your reply. Thanks!
2018-3-31
davidmartingraf
Aardvark Posted at 2018-3-31 06:46
That is a good savings amount of quid..
2018-3-31
SparksBird
Flight distance : 10731690 ft
Making me add this to my must have list now as well.
2018-3-31
davidmartingraf
SparksBird Posted at 2018-3-31 12:13
Why not? Might as well, you do own a Mavic Pro?..
2018-3-31
