GB44
Flight distance : 343848 ft
If you take some images in Raw then review, if there are dead pixels it probably means the camera has dead pixels on the sensor. I had similar with my First issue aircraft and I know another owner who also had same problem with camera which had the same production date, with were from the first issue batch in January.
I would suggest you take the unit back to your dealer for replacement as its not fit for purpose. Take some sample images in on your iPad to demonstrate the dead pixels. You can't expect software and alogorythims to be the answer if the sensor has dead pixels thats just masking the problem that shouldn't be there from the start. |
