KedDK
Flight distance : 1133038 ft
Denmark
It is a dammed virus! - agree with the ones suggesting to turn off the OA sensors.
Was out shooting one site, move on to the next 20 min after on next location, everything set up, power on, waiting for GPS, took off ground and could not move in any direction!
Powered both AC adn RC off/on, waited for GPS, took off and the same thing. Powered off AC and calibrated sticks and gimbal wheel without issues, sticks was working fine.
Powered AC on, waited for GPS, took off and still no response on right stick at all, could go up/down and yaw that was it. packed down and went home.
Back at home i tried again, still no movement on right stick, disabled OA, took off and then it shoot to the right almost vertical when i touched the stick and everything seemed back to normal.
So disable of the OA system did it, not sure when/why it was acting like this as i normally has sensors off and only the "Radar" active, OA was turned on at the first site due to some trees i had to be close to but no issues during that flight.
Will try to clean all sensors but doubt it has to do with it as the radar would have shown obstacles all the time in case of dirty sensors.
Best of luck to you. |
