I have a LG G Pad 8.3 LTE (Verizon) Model - VK810 4G. I was able to get USB Debugging activated following these instructions - http://www.verizonwireless.com/support/knowledge-base-95463/ but it is still not getting a connection with my Phantom 3 Pro RC. Once I got debugging switched on and connected the tablet to the Phantom RC USB port the Select USB connection method display opens. The default is "Media sync (MTP)" but selecting any of the other options "Charge tablet"; "Internet connection"; or "Camera (PTP)" has no impact. The items under the Settings / System / Developer options including the checked box beside Debugging / USB debugging is grayed out. What am I missing here?
Thanks war550 - confirmed those settings, but the LG G Pad 8.3 is running 4.4.2 and still not connecting. FYI My Droid MAXX phone running 4.4.4 works perfectly with the DJI Pilot app.
Update - just chatted from DJI and their opinion is the LG G Pad 8.3 is probably not compatible with the DJI Pilot app.... RATS!
someone figured out how to solve the problem of compatibility with Lg g pad v500 ? I bought only for use with phantom 4, but when I download the DJI GO had the misfortune of incompatibility warning . If atualizer android to 5.1 could solve?
Below are the devices that work with DJI aircraft.
Anything else may work, partially work, or not work at all.
This is due to the processing power required to run the GO app.
