Mavic PP Gimbal gone crazy
1156 10 2018-5-5
RodrigueElHajj
Flight distance : 17264 ft
Hello,
Was in the mid air and suddenly the gimbal went crazy for a while, it fixed itself after around 30 sec. But before that it got stuck while yawning then it started rotating around then it switched from manual to auto focus, defocused switched to cam mode from video and then all got fixed. (i'm just talking about the gimbal the aircraft didn't move)
Happened twice in two flights.
Should I be concerned? or is it a bug from the app that got fixed with today's update (on android) didn't try it yet.
2018-5-5
A CW
Flight distance : 14588274 ft
Random gimbal disconnects happened on my previous, original Mavic but yet to happen on my MPP. Try resetting the camera when back at home, refresh the FW and ensure you're on the latest version of the FW (using Assistant 2) and the GO4 app. This strangely has been known to be caused by the micro SD card but don't ask me how. I'd also calibrate the gimbal too. Are you using ND filters?
2018-5-5
RodrigueElHajj
A CW Posted at 2018-5-5 05:41
I actually did change the SD card had sandisk extreme plus and switch to sandisk extreme. FW refresh was done just before I leave home. I redid another one when I got back just incase and I am on the latest FW version.
Yeah I had an ND filter on it but never happened before and was using the same filters.
Could it be the SD card?! strange
As for the gimbal calibration I did one just before the flight, I though it was due to that (bad calibration) but then everything worked perfectly.
And when I changed the battery it happened again
2018-5-5
A CW
RodrigueElHajj Posted at 2018-5-5 05:46
Is it the first time this has happened and since switching the SD card?
2018-5-5
RodrigueElHajj
A CW Posted at 2018-5-5 05:48
yeah it's the 1st time I fly with the new SD
2018-5-5
A CW
RodrigueElHajj Posted at 2018-5-5 05:49
Looks like you have your answer mate. Put the extreme plus back in and format it. Whilst the SanDisk extreme is compatible your specific card may be corrupting the drone in some way. Try switching and fly again. If it stops resetting the gimbal mid flight then voila!
2018-5-5
RodrigueElHajj
Yeah I'm gonna try that thanks again for the help man!
2018-5-5
dwainwayne28
Flight distance : 583323 ft
Trinidad and Tobago
This exact thing happened to me about 1 month ago. I brought it down and did a restart and re-calibration and it was resolved.
2018-5-5
A CW
RodrigueElHajj Posted at 2018-5-5 05:55
No probs - let us know if it happens again.
2018-5-5
DJI Diana
Flight distance : 2408 ft
Hope everything will be fine soon. If there is any further issue, please feel free to let us know, we'll here for help.
2018-5-6
RodrigueElHajj
DJI Diana Posted at 2018-5-6 23:45
Hello sorry for the late reply but didn't have the time to try it out before, so switched back to my old microSD tried 3 times today completely flying turning it off changing battery and flying again, and it didn't reset by itself so hopefully this problem is fixed. Thank you
2018-5-12
