Bashy
Flight distance : 2354357 ft
if you are on about the uv filter then lick 1st 2 fingers and thumb, then ever to gently hold the lens with fingers and thumb in equal 3rds on the lens and unscrew, if it does not move then you are gripping too tighly, keep equal pressure between fingers and thumb and unscrew, the touch needs to be so light that your fingers are hardly touching it, the lighter the touch the better it will unscrew, its made of plastic so any uneven pressure will cause it to grip the thread and make it near on impossible to unscrew...
