Geebax
Dhillskiier1653 Posted at 2018-5-13 15:04
I installed the app you recommended and still no luck. Could it be a controller connection issue? I had a much cheaper phone before that ran perfectly with no lag at all but as I can see many other people are having the same issue. I think it might be because of the update.
The later updates have increased the requirements for the device, they are doing more processing than before. Anyway you look at it, the phone needs to do more work faster, and so if the screen lags behind significantly, then it is not processing the video information fast enough. Comparing the processors in each phone means nothing, most of the issue is how the phone processes the incoming video, and that often has more to do with the efficiency of the code than the processor alone.
